West Serving AZ, CA, HI, NV
AV ELECTRONIC UNIT
Old May 25, 2004 | 06:14 PM
g_fatha's Avatar
AV ELECTRONIC UNIT
Anyone here do the av tuner install? Is there a good shop in OC that sells the unit and does the install?
Old May 25, 2004 | 09:47 PM
g4s's Avatar
g4s
Re: AV ELECTRONIC UNIT
the install is not too bad once you review the disassembly of the dash a few times. plus you get the gratification of doing it all yourself. i'm not much help b/c i don't know of any shops in socal that have done this, but i'm sure there are some out there.
here is a very detailed diy if you want to tackle taking apart the dash yourself. i believe there is a diy on the same site for an automatic as well. i just can't find the link atm. good luck.
oh and purchase the unit from iksardarg. he's top notch and will not find a better price without a huge groupbuy.
Old May 27, 2004 | 11:44 AM
AznIceRckt's Avatar
diy diy! its easy... there aren't wiring harnesses that work (i think), so you can pay al and eds like 60 to wire in the alpine harness, then everything else is plus and play easy. pulling out the passenger seat is cake, and then the floor's of the g35's are padded with thick-foam, which can be easily cut or removed to make room for the brain (and therefore not lift the carpet)...
to do it this way, you have to run all new wires to the speakers tho, which will improve your sounds quality (and is how all systems should be wired). running wires through the smj harness is made easy in the FAQ section of the DIY-sedan signal mirror install.
the factory service manuals are also all online and show you how to take the entire interior (and car for that matter) appart.
*** 2003 G35s 5a/t / Pearl White ***
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Oregon13
Mar 1, 2016 12:06 AM
