Kics Project Spacers in Stock!!!!
Old May 22, 2009 | 01:00 PM
  #91
Mike@CZP's Avatar
bump
Old May 26, 2009 | 04:50 PM
  #92
Slayer33's Avatar
Originally Posted by Mike@CZP
bump
I'm interested.. I might be coming down at the end of June for work.. I think Tempe, AZ.. is that close to your shop?
I'm a little puzzled at how these work.. do they bolt onto the existing factory wheel studs? and then the new studs bolt onto the wheel?
How does the factory wheel clear the oem stud/nut?
what size do you recommend for an 05 coupe with the oem 19" wheels? and should I do both front and back?
Old May 28, 2009 | 11:45 AM
  #93
Mike@CZP's Avatar
bump
Old Jun 3, 2009 | 12:09 PM
  #94
Mike@CZP's Avatar
bump
Old Jun 11, 2009 | 12:59 PM
  #95
Mike@CZP's Avatar
bump
Old Jun 15, 2009 | 06:43 PM
  #96
Mike@CZP's Avatar
bump
Old Jun 17, 2009 | 03:26 PM
  #97
Mike@CZP's Avatar
bump
Old Jun 19, 2009 | 01:35 PM
  #98
Mike@CZP's Avatar
bump
Old Jun 23, 2009 | 02:20 PM
  #99
Mike@CZP's Avatar
bump
Old Jun 29, 2009 | 05:32 PM
  #100
Mike@CZP's Avatar
bump
Old Jun 30, 2009 | 01:46 PM
  #101
demented's Avatar
Spacers
Do you guys have the Kics 10mm spacer in stock? If so can you PM a total shipped with also a pair of 10mm Ichiba V1 spacer to 92126. Thanks.
Jason
Old Jun 30, 2009 | 02:41 PM
  #102
Mike@CZP's Avatar
PM Sent
Old Jul 2, 2009 | 07:57 PM
  #103
Mike@CZP's Avatar
bump
Old Jul 8, 2009 | 03:42 PM
  #104
Mike@CZP's Avatar
bump
Old Jul 10, 2009 | 01:38 PM
  #105
Mike@CZP's Avatar
bump
