WedsSport Superlight Weight Track Wheel ****
Old Feb 24, 2010 | 12:54 AM
RAVSPEC's Avatar
hey All:
Just got our hand on some WED sport lightweight track wheels. Anyone interested, please give us a call !
TC105N - $2089 Shipped to lower 48 states (AMF Technology)
Titanium Bronze Color
Available Spec:
18x9.5 +10 (17.6 lbs per wheel)
18x10.5 +12 (18.37 lbs per wheel)
Old Feb 24, 2010 | 12:55 AM
RAVSPEC's Avatar
WedsSport SA70 - $2657 Shipped to lower 48 states (AMF Technology)
18x9.0 20mm offset / 18x10.0 18m offset
Blue Light Chrome Color
Old Feb 24, 2010 | 12:56 AM
elayman's Avatar
the TC105s are sex. I wanted these before getting my Enkeis but these are a little more pricey.. definitely worth it though . the SA70s are really good looking too, but aren't aggressive for a coupe
Old Feb 26, 2010 | 12:38 PM
RAVSPEC's Avatar
weekend bump !!
Old Mar 9, 2010 | 07:38 PM
RAVSPEC's Avatar
quick bump ....
Old Mar 11, 2010 | 10:21 AM
RAVSPEC's Avatar
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
Old Mar 17, 2010 | 11:52 PM
RAVSPEC's Avatar
quick bump ....
Old Mar 19, 2010 | 01:27 AM
RAVSPEC's Avatar
18x9.5 TC105N are lighter than same spec RPF1
Old Mar 19, 2010 | 01:30 AM
Beebo's Avatar
sedan offsets?
Old Mar 19, 2010 | 02:03 AM
valetkyle's Avatar
no 19"s?
Old Mar 19, 2010 | 10:57 PM
RAVSPEC's Avatar
only the SA55M and SA67R comes in 19".
TC105N and SA70 doesn't have 19" setup.
Old Mar 24, 2010 | 12:04 AM
RAVSPEC's Avatar
quick bump !!!
Old Apr 3, 2010 | 01:37 AM
RAVSPEC's Avatar
WEDSSPORT SA55M 18" / 19" Group buy Link **** 18" Red Accent
https://g35driver.com/forums/group-b...e-concave.html
obender66
18 Inch
Mar 13, 2016 12:20 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
Gip
Aug 24, 2015 05:31 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
mushu
Jul 15, 2015 03:55 PM
