WEDSSPORT Lightweight Tuning Wheel - New Release SA55M w/Blue Ascent @@@ MUST SEE !!!
Old Mar 6, 2010 | 12:20 AM
RAVSPEC's Avatar
**** FREE SWIFT SPORT SPRING FOR G35 Coupe w/ Purchase ****
Hey guys:
Just got new release of these WEDSSPORT SA55M Lightweight AMF (Advanced Metal Form) Cast One piece wheel.
(new AMF Technology)
Two color Options:
MGM - Regular Matt Gun Metal Color
BBM - Blue Clear Coat / Blue Trim with Black Face
BRM - Red Clear Coat / Red Trim with Black Face *** 18x9.0/10.0 only ***
*** PM for Pricing - Starting at $2050 Shipped **
For Limited Time Only
Free KICS Leggdura Lightweight Lug Nuts (under 1/4 lbs per corner) OR
Free SWIFT SPORT Spring @ $400 Retail !
** 19 lbs ~ 20 lbs **
18x9.0 +20mm Offset **Semi Aggressive Concave Face**
18x10.0 +18mm Offset **Full Aggressive Concave Face**
** Weight - TBA **
19x9.5 +15 or 24mm offset **Full Aggressive Concave Face**
19x10.5 +15 or 24mm offset **Full Aggressive Concave Face**
FREE KICS Lightweight Lug Nuts ** Perfect Combo with these wheels
Comes in blue,black,red,black,pink,green,gunmetal color -Under 1/4" per set of 20 lug nuts / 22 grams each
Actual Pics of 18x9.0 SA55M +20mm offset in MGM Color
Actual Pics of 18x10.0 SA55M +18mm offset in BBM Color
Old Mar 6, 2010 | 04:09 AM
J2S2M's Avatar
Wow these are hawt! They look very much like the Advan RZ but I love the bluish black color. That color is ridiculous!
Are the 19's offered in any other offsets??? A bit too aggressive for the sedans :\
Old Mar 6, 2010 | 08:23 AM
RAVSPEC's Avatar
yeah, you got these options:
19x9.0 +38 or +45
19x10.0 +40
LMK if u need some pricing.
Old Mar 6, 2010 | 08:47 AM
RAVSPEC's Avatar
Old Mar 6, 2010 | 12:45 PM
J2S2M's Avatar
19x9.0 +38 or +45
19x10.0 +40
Can you get 19x9 F +25ET 19x10 R +30ET if not something close to those specs? Price shipped to 92620 for both colors.
Thanks.
Old Mar 6, 2010 | 05:07 PM
RAVSPEC's Avatar
Thanks.
how about 19x9.5 +24 and 19x10.5 +24 ?
Old Mar 7, 2010 | 01:17 AM
J2S2M's Avatar
^ PM me your best price shipped to 92620
Old Mar 7, 2010 | 09:55 AM
Forged_G's Avatar
How much shipped to 06905?
Old Mar 7, 2010 | 07:13 PM
RAVSPEC's Avatar
hmmm .. which size / setup ?
Old Mar 8, 2010 | 12:56 PM
SteveBlake's Avatar
Any more aggressive offsets for the 19's?
Old Mar 8, 2010 | 04:05 PM
RAVSPEC's Avatar
nah .. that's it .. 19x10.5 +15mm
Old Mar 11, 2010 | 10:18 AM
RAVSPEC's Avatar
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
Old Mar 17, 2010 | 11:51 PM
RAVSPEC's Avatar
quick bump ....
Old Mar 19, 2010 | 02:07 AM
valetkyle's Avatar
how much for 19"s in coupe fitment shipped to 30022?
Old Mar 19, 2010 | 10:49 PM
RAVSPEC's Avatar
Pmed !!!
