WEDSSPORT Lightweight JDM Tuning Wheel **** In Stock Special ****
Old Jun 17, 2010 | 11:46 PM
RAVSPEC's Avatar
Ask for tire package !! ** In Stock Special
WEDSSPORT TC105N - 18x9.5 35mm offset 5x114.3 Bronze ** 17.6 lbs
WEDSSPORT SA55M - 18x9.0 20mm offset, 5x114.3 Gun Metal ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 20mm offset, 5x114.3 Blue Accent ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 36mm offset, 5x114.3, Gun Metal ** 19.5 lbs
WEDSSPORT SA55M - 18x9.0 36mm offset, 5x114.3 Blue Accent ** 19.5 lbs
WEDSSPORT SA55M - 18x10.0 18mm offset, 5x114.3, Gun Metal ** 20.4 lbs
WEDSSPORT SA55M - 18x10.0 36mm offset, 5x114.3, Gun Metal ** 20.4 lbs
WEDSSPORT SA55M - 19x9.5 +15mm or 24mm offset, 5x114.3, Gun Metal / Blue Accent Pic Links
WEDSSPORT SA67R - 18x9.0 20mm offset, 5x114.3, Gun Metal ** 19.2 lbs
WEDSSPORT SA67R - 18x9.0 36mm offset, 5x114.3, Gun Metal ** 19.2 lbs
WEDSSPORT SA67R - 18x10.0 15mm offset, 5x114.3, Gun Metal ** 20.0 lbs
WEDSSPORT SA67R - 19x8.0 35mm offset, 5x114,3 Gun Metal ** 20.5 lbs
WEDSSPORT SA67R - 19x9.0 +35mm offset, 5x114, Gun Metal ** 20.9 lbs
Hey All:
Weds Japan - one of the top wheel manufacturer in the world. Their wheels line up included lightweight tuning wheels that are being use in JGTC and many racing circuit and luxury sport wheels that are popular on the street of Tokyo. Their newest lightweight tuning wheel series "Wedssport" series included SA55m, TC105N, SA67R and SA70. Using the newest AMF flow form casting technology, Weds Japan bring you the lightest tuning wheel in the market. (see below for AMF definition)
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
Old Jun 17, 2010 | 11:47 PM
RAVSPEC's Avatar
Old Jun 17, 2010 | 11:48 PM
RAVSPEC's Avatar
WEDSSPORT SA55M (BBM - Blue Black Machining) Color.
Old Jun 26, 2010 | 06:21 PM
RAVSPEC's Avatar
WEDSSPORT SA55M 19x10.5 +24mm BBM Color
*** First set in the nation ****
Old Jul 3, 2010 | 12:05 PM
RAVSPEC's Avatar
WEDSSPORT SA67R , RR Face, 18x10.0 +15mm offset, Gun Metal Color
Old Jul 8, 2010 | 07:01 PM
Locksmith's Avatar
TC105N in 18's for a 2008 G35x Sedan shipped to 55449?
Old Jul 9, 2010 | 05:42 PM
RAVSPEC's Avatar
PM Replied !
Old Jul 9, 2010 | 06:21 PM
VatosLocos35's Avatar
WEDSSPORT SA67R 19' for 04 g35 coupe with brembos shipped to toronto, CAN M1G 2P5
Old Jul 9, 2010 | 06:51 PM
chinabean's Avatar
WEDSSPORT SA55M (BBM - Blue Black Machining) Color shipped to 85353
Old Jul 12, 2010 | 03:33 PM
RAVSPEC's Avatar
I got the 18x9.0 +20mm front and 18x10.0 +18mm Rear in stock ready to ship.
$2200 shipped. With free center caps, hub rings, color matching valve stems + lug nuts (blue, red or black).
In stock now.
19" will not be in stock till end of August.
19x9.5 +15mm / 19x10.5 +15mm BBM. And only 2 sets left. $2450 shipped
Same free stuff.
Also for limited time only, Free Swift Sport spring with purchase ($400 value)
Mark.
Old Jul 13, 2010 | 11:18 AM
WierdAznDude's Avatar
TC105N in 18's shipped to 63111
Old Jul 13, 2010 | 12:16 PM
RAVSPEC's Avatar
PM sent ... on clearance now !
Old Jul 13, 2010 | 12:38 PM
RAVSPEC's Avatar
WEDSSPORT SA55M in BRM (Black Red Machining) *** Production Wheel ***
Just got the sample wheel from Japan. / Enjoy
Old Jul 17, 2010 | 01:07 AM
RAVSPEC's Avatar
Weekend bump !
Old Jul 17, 2010 | 04:29 AM
chinabean's Avatar
are the red ones the same pricing ? im really tempted but if i pull the trigger they won't be going on my g35 - tough choices lol =/
