Muteki, MXP and Kics lug nuts and Lock sets in STOCK
Any of the lug nuts above will work with the GTV wheels. Let me know if you have any questions about them.
Charles
Charles
the key for all of them fits to tighten inside the lug holes? do you know the size of the key to tighten the lugs because a 17mm socket im using barely fits the stock lugs now inside the holes and is scratching the wheels? and the length of the 35's vs. the 48's..and above i see someone asking about kics r40's, i didnt see them listed what is the length on those too..thanks
Sorry for the late repley. They do have a thin wall key. They have a dual key. You can use 19mm or 21mm. The Kics R40 are about the same lenght as the SR48. Just alittle shorter.
Charles
Charles
