Hankook Ventus V12 Evo 19" Tires IN STOCK
Old Jun 13, 2012 | 08:57 PM
Arcee@OCInfiniti's Avatar
HANKOOK VENTUS V12 EVO TIRES ON SALE AND IN STOCK!
225/40ZR19 - $199.95 EACH
245/40ZR19 - $214.95 EACH
OTHER SIZES AVAILABLE SO PLEASE CALL 714-650-8586 FOR PRICING!
FEATURES
The solid rib block in the center enhances braking performance.
It also ensures optimal ground contact pressure and control
response at high speeds for excellent handling.
Efficient water drainage thanks to wide linear groove and Y-shape pattern design. Wide linear grooves and an aggressive Y-shape pattern design effectively channels water away from the tire. This means safe driving on rainy roads.
Wide linear grooves, Y-shape pattern
Improved water drainage
High-densitynylon reinforcement belt
Optimized structure featuring a high-density nylon belt leads to even distribution of ground contact pressure during cornering
Ventus V12 Evo pattern provides more even ground contact when cornering versus existing products
Old Oct 2, 2012 | 05:03 PM
daily_stanced's Avatar
do you still have the hankooks in
245/35/19
265/35/19
255/35/19
obender66
18 Inch
Mar 13, 2016 12:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
realtalk21
Jul 20, 2015 09:07 AM
