steering wheel shakes
Old May 25, 2006 | 12:34 AM
switches1866's Avatar
i put my stock wheels back on and my steering wheel shakes when i drive. what can it be. thanks.
Old May 25, 2006 | 12:38 AM
GLuXuRy's Avatar
make sure you wheels are mounted correctly
EDIT: or maybe some how your wheel weights fell off
Old May 25, 2006 | 12:44 AM
I will check on the weights. Is there a wrong way to mount them.
thanks
Old May 25, 2006 | 12:45 AM
GLuXuRy's Avatar
no... but sometimes they may look like they are set properly and when you drive you will see the rim wobble
EDIT AGAIN: Have someone look at every wheel while you drive slowly and see if the wheels wobble
Old May 25, 2006 | 12:09 PM
cato's Avatar
SouthernComfort Moderator
Steering wheel shake is usually caused by unbalanced wheels!
Old May 25, 2006 | 09:32 PM
They told me it was not the balancing. The guy said it was the front tires. They are no good.
Old May 25, 2006 | 10:08 PM
BracketRacerSteve's Avatar
The guy? What guy? The guy on the corner smoking crack or the one at the tire shop trying to sell you tires?
Old May 25, 2006 | 10:26 PM
lawrence's Avatar
how did you store the tires ?
did you stack them , or set them on the ground.
as in the tread in one spot for a long time,
this can flat spot the tires.
drive the car for 1/2 hour at highway speed to see if it goes away.
Old May 25, 2006 | 10:29 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
What did you have on b4??
Did they have hubcentric rings?
Maybe you left them on.
Old May 25, 2006 | 10:39 PM
I had 20s on before. Yes I stacked them. Drove it to work and back and it did not go away.
Old May 26, 2006 | 12:03 AM
lawrence's Avatar
call your local nissan or infiniti dealer and find out if they have a wheel balancer made by Hunter " DSP9700"
it can measure radial force vareiation in tires and rims,
this will give a printout of RFV for rim and for tire.
use this info to find failed wheel /tire.
get the print out and return tire for defect proration.
Old May 27, 2006 | 08:45 PM
Basheer's Avatar
Call the Cops
infiniti will fix it for you
55-110 dollars depending on how much balancing you need.
Old May 30, 2006 | 01:41 AM
SuperRep's Avatar
tire shakes
could be the hub rings. some wheels come with plastic hubrings.
Old May 30, 2006 | 08:30 AM
InTgr8r's Avatar
I sugested that earlier.... still don't think he got it.
If this is the case it's usually extreme shaking vibration, not subtle.
Sometimes when you take off an aftermarket wheel the hub ring stays on the hub. (& some times not)
Always check!!
Old May 30, 2006 | 08:50 AM
JEVERYDAY's Avatar
maybe an alignment
