Thumpety, thump, thump
Old Jun 27, 2006 | 12:35 PM
Gashed's Avatar
There's been a lot of heated debate over the premature tire wear / feathering issues leading to tire "roar". Now hear me out for a second. I have a noise problem that is a little different. At low speeds (15 - 30 mph), I hear an oscilating thump, thump, thump, thump coming from the front end. Is this also related to the way the suspension is set up? Someone told me that it is a tire balance issue and all I need to do is rotate the fronts side to side and rebalance. I just don't understand why it is happening (again). It happened on my OE tires and is starting up again after 4000 on my new set.
Thanks for the tips!
Old Jun 27, 2006 | 02:36 PM
kenchan's Avatar
you mightve generated some flat spot memory from low inflation.
wats your psi? (or better yet, when was the last time you checked your
tire pressure?)
Old Jun 27, 2006 | 03:00 PM
Gashed's Avatar
35 psi on both. I'm going to have the alignment checked to be safe.
Old Oct 2, 2007 | 09:01 AM
happydude's Avatar
Any new news on this? I'm having a similar problem. What did you do and what happened?
Old Oct 4, 2007 | 08:25 AM
happydude's Avatar
bump
ddietz97
Jul 26, 2015 06:16 PM
obender66
Nov 28, 2008 03:37 PM
AlcatrazT2
Feb 4, 2007 08:20 PM
mbailey
Jul 16, 2003 03:52 PM
