Rims (help!)
Old Jul 13, 2006 | 09:41 PM
Mr Nismo's Avatar
Thumbs down Rims (help!)
I'm lookin to get some Volk 19's but I don't know which one's to get.
Can someone help me! here are the size's..
19x9.5, 5x114.3 bolt pattern 22mm offset
19x8.5, 5x120 bolt pattern, 30mm offset
19x10.5, 5x120 bolt pattern, 25mm offset
19x10.5, 5x114.3 bolt pattern, 22mm offset
Thanks guys
Old Jul 13, 2006 | 09:54 PM
ON's Avatar
ON
i'd go with the last choice, 19x10.5, 5x114.3 bolt pattern, 22mm offset
you can't put 5x120 pattern on the G.
not sure if the offset will work, someone help him out with that. ^_^
Old Jul 13, 2006 | 10:29 PM
Mr Nismo's Avatar
alright well thank you
Old Jul 13, 2006 | 10:47 PM
HotRodW's Avatar
The correct bolt pattern is 5 x 114.3. I assume you have a coupe, so to keep the staggered look you'll want the 9.5" wheels up front, and the 10.5" out back. 22mm offset sounds about right, but your dealer should know for sure.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
