Will these fit?
Old Jul 15, 2006 | 10:37 PM
krookid's Avatar
Will these fit?
I have 20" Kaotic GT's off my 2005 G so the offset is correct(not sure what it is) My question is I never had my 05 lowered so I went with 245/35/20 all the way around, and had no fitimnet or rubbing issues, but I want to put them on my 06 that I have lowered with Tein s-techs and I am wondering if they will fit the fronts? I used the tire size calculator and it is a perfect match for the back but 0.69 inches bigger than the front oem size, so I was wondering if they will fit? I was told because it is lowered the wheels actually sit kind of angled so it shouldn't be a problem. The reason I am asking the question and not just trying to see if it will work, is that the wheels are in my parents garage and it is 700km away. I don't want to drive all that way for nothing. Any help will be greatly appriciated. Thanks in advance.
Old Jul 15, 2006 | 11:08 PM
ssk0771's Avatar
ZZ Boy
You should not have any problem. Especially if you have Coupe.
Old Jul 16, 2006 | 06:12 PM
krookid's Avatar
I do have the coupe, I guess its going to be no problem then, anyone else tho?
Old Jul 17, 2006 | 01:02 AM
ssk0771's Avatar
ZZ Boy
The main thing is the offset of the wheels. As long as they are correct offsets, you will not have any issue WHAT SO EVER.
G35C can take pretty wide arrange of offset but just make sure they are aggressive enough. Was your 2005 G35 coupe or sedan. If it was sedan, your offset is going to be too conservative. That doesn't mean its not going to fit but it might not look right. It will look too tucked in.
What is your wheels Size and offset?
Old Jul 17, 2006 | 05:54 AM
krookid's Avatar
The 05 was a coupe, not sure of the offset tho but it looked exactly "right", I know the wheels will fit for sure but I am more concerned with rubbing issues due to me having my 06 lowered.
Old Jul 17, 2006 | 02:53 PM
ssk0771's Avatar
ZZ Boy
You should be fine.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
