Staggered set up 19x8/ 19x10 on Sedan?
Does anyone have pics of a Sedan with a staggered set up? I'm planning on 19x8 (245/35) front and 19x10 (275/30) rear and was just curious to see the visual affect before I order the wheels and also what offset did you go with on the rear? I know everyone keeps saying 55+ but I'm thinking of going mid 40's. I'm not worried about rubbing cause I could always flare the fenders a little.
P.S.
For those who care. I drive a Silver Sedan 6MT CA license plate "KRZ HAYN" = "Krazy Hawaiian". A "Shaka" is always welcome.
P.S.
Re: Staggered set up 19x8/ 19x10 on Sedan?
I've got a staggered set up on a sedan. Check my profile for pics of my sedan with Axis Supermesh. 19x8.5 in the front and 19x9.5 in the rear with a 45 offset. Tires are 245/35 up front and 275/30 in the rear. The rears are flush with the fender and I've experienced absolutely no rubbing. I can't imagine going wider with the 45 offset. Hope that helps...
Dan
Dan
Nice g35funk. Those fat 275s look mean back there! Are you thinking of lowering your car at all? ... the back may rub if you do ... or will they?
On another note, have you had a chance to push her a little harder w. the staggered setup? How did you like the handling w. VDC off? was it more understeer or oversteer (compare to stock setup)?
THX723<P ID="edit"><FONT class="small"><EM>Edited by THX723 on 10/11/03 11:17 AM.</EM></FONT></P>
g35funk,
so, was that a 'yes' to RacerX's questions on 45 offset to the
fronts?
RacerX,
You wouldn't happen to know what the stock offsets are for the SEDAN?
THX723
fronts?
RacerX,
THX723
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
