Series designation of Tires
Old Jul 23, 2006 | 10:22 PM
dp_PRIME's Avatar
It's about time for me to change my tires, so i was going with my traditional V-series tires, but these guys at the dealer was harassing me about how I def should go with the W or Y- series tires since my car is a sports car. I didn't think much of it, but the guys go off about how if you don't have the right series tires your stearing may be off, suspension won't be as good, turns will be wide, breaking power could be hindered, as well as performance in rain/snow is worse...etc etc.
My friend's got the 350Z, which come stock with V-series tires and dropped down to the S-series b/c it was cheaper. And he doesn't seem to have problems at all. So i don't see why i should increase them unless i'm wrong and the series of your tires makes that much of a difference. Anyone know about how much of a difference the tire series makes on ur car??
Old Jul 23, 2006 | 10:26 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
unless you plan on going over 120 you dont need W or Y speed rated tires.
-GP-
Old Jul 23, 2006 | 10:38 PM
dp_PRIME's Avatar
Is there a difference between S and V-series tires? Since my friend's 350Z seems to be fine, i figure it'll be cheaper on my wallet.
Old Jul 23, 2006 | 10:42 PM
The difference is the speed rating. A 'V' rated tire is able to perform at higher speeds than an 'S' rated tire. V rated tires are up to 150mph where the S rated tire can only go up to 112 mph.
-GP-
Old Jul 24, 2006 | 02:18 AM
Rascal's Avatar
Well with a lower rated tire you could go faster than the rated speed but you risk the tire coming apart. If you don't go faster than 100, you could go with a S. But it's better to get the best tires you can afford. It's a 40 grand car why take a chance trying to save $100-200.
Old Jul 24, 2006 | 09:30 AM
tomcatm's Avatar
I think you are fine with the V series tire ( doubt you will ever drive above 150 ), but you shouldnt go below that on a G.
jsimonk
Dec 22, 2023 03:49 PM
b2autodesigns
Accessories-Vendor
84
Jun 20, 2017 04:38 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Team STILLEN
Aug 10, 2015 08:17 PM
