What size tire for 20x8.5 / 20x10?
Old Jul 26, 2006 | 09:41 AM
FamousG's Avatar
Hey guys, just needed some feedback on what size tire I should run for some 20's. The tire calculator doesn't help because of the difference in the width of the wheel. I have OEM 18" wheels (225/45/18 front, 245/45/18 rear) on my G35 coupe which is stock height without Brembos. The wheels I'm looking into getting are 20x8.5 in the front and 20x10 in the back. I wanna run as close to stock specifications as possible. Thanks.
Old Jul 26, 2006 | 10:25 AM
JoEY C's Avatar
Go With 245/35 - 275/30 Or 245/35 - 275/35..also Depends What Tires You'll Be Running On..some Have A Meatier Sidewalls Then Others
Old Jul 26, 2006 | 04:17 PM
DHCrocks's Avatar
to be as close to stock diameter as possible you would need 255/30/20 and 285/30/20. That will just about be dead on. stock is 25.98" and 26.69", those sizes will be 26.02" and 26.73". That's as close as you'll get.
Old Jul 26, 2006 | 06:23 PM
sen_jen's Avatar
Meatshake Enterprise
took the words right out of my mouth! any more, you'll have problems when lowering your vehicle. you can run the sizes the DHCrocks is using, but if you lower it more than an 1"+ you'll run into probs. the tire brands play a role in sizing/clearance as well.
Old Jul 26, 2006 | 06:27 PM
anDross's Avatar
im stretched to fit going.. 255/35 - 285/30 on falken fk451's ..
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
BlackGee35
Jul 31, 2015 11:04 AM
