18x8 wheel question
Old Oct 12, 2003 | 02:10 AM
Rspec's Avatar
18x8 wheel question
can any1 tell me If 18x8 35offset will fit g35c without anyproblem? I know stock is 18x8 30offset.
does 5more offset makes any difference????
Nuttin chillin in da holydae in
Old Oct 12, 2003 | 06:41 AM
RaySur350GT's Avatar
Re: 18x8 wheel question
It will be no problem, it will just be a little more tucked in. You probably won't even notice it...
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Oct 12, 2003 | 09:19 AM
Rspec's Avatar
thanks alot. So the more higher the offset is the more tuck in..
right?
Old Oct 12, 2003 | 12:29 PM
Rspec's Avatar
I'm trying to get a set of 18x8 rims with 35offset.
Should I get a 18x9 on the rear or it's ok to get just little wider tires for the rears like Stock rims.?
Old Oct 12, 2003 | 02:58 PM
Your answer to the first question is correct. The higher the offset, the more the rin is positioned inside the wheelwell.
Now the size of the rim part, are these rims for winter use (snow ect..)? If so then you usually want a smaller width like 7or 8".
But if these rims are for normal street use, then I would go with 8 to 10.5". On normal use i say wider is better, goes with wider tires also like 275s.
Old Oct 15, 2003 | 11:46 PM
spinn's Avatar
are the Performance Pkg 18" rims all 18x8? or are the rears wider?
Old Oct 16, 2003 | 04:00 AM
ryoken's Avatar
all 18x8, it's just the tires on them that are wider in the rear.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
