Question about TPM on volk progressive TE's
Old Sep 14, 2006 | 11:38 AM
Ginsengboy's Avatar
After a quick search over previous threads it appears various people have had success with re-installing their TPM's on their after market rims. I am considering getting Progressive TE's 19" or the Gram Lights 57s (18" or 19"). Has anyone had experience with these volk rims and getting the TPM to work right?
Also, did you use the OEM TPM? or did you have to get something else?
Old Sep 18, 2006 | 09:21 PM
Ginsengboy's Avatar
I guess noone has any experience with tire pressure sensors on their volk rims...
do people not have them b/c it's not possible? or just not worth the trouble?
Old Sep 19, 2006 | 07:45 AM
Coach's Avatar
The first thing you have to do is make sure that they fit the rim. Some rims
have an inside contour that won't let the sensor case lay flat and the stem
exit correctly. Your shop should be able to tell you if the Schraeder sensors
will work with your rim choice.
Assuming the sensors will physically fit the wheels, you will need to get the
BCM reprogrammed if the pressure you are running in your new tires is
different fronm your old tires (common with upsizing).
Old Sep 21, 2006 | 01:11 PM
jdmeg21's Avatar
so if I don't get the tps on will I have that stupid tps light on all the time. (_I_) <----this light
Old Sep 21, 2006 | 01:44 PM
Calvin's Avatar
Overglorified Altima
i believe so, yes
Old Sep 21, 2006 | 05:51 PM
Ginsengboy's Avatar
Thanks usual_suspects.... I guess i'll have to ask around to a few more shops. One place i went to doesn't think any of the volks will be able to mount the tire pressure sensor.
I was hoping someone would have a set of volks with the TPM's functioning properly.
Old Sep 22, 2006 | 07:52 AM
Coach's Avatar
No, just get your dealer to disable the system.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
neight
Aug 3, 2015 11:27 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
