RAYS OEM 19s QUESTION NEED QUICK ANSWER PLEASE
Old Nov 19, 2006 | 11:11 PM
stasfire's Avatar
I have an 03 g35coupe and i bought the O5 OEM19's. I am purchasing tires tomororrow and wanted to know if i can put 235/35/19F 255/35/19R. Please give me some advice.
Old Nov 19, 2006 | 11:18 PM
filanj's Avatar
look it up on tirerack.com
Old Nov 19, 2006 | 11:34 PM
EricIsKlumzyee's Avatar
yes u can
Old Nov 20, 2006 | 02:52 AM
j-velocity's Avatar
you will be fine.
I am running 235/35R19F and 265/30R19R.
Old Nov 20, 2006 | 04:03 AM
sngpimpin's Avatar
on the stock 19s? how would a 255 look with the stock 19s?
Old Nov 20, 2006 | 06:50 AM
lowrider's Avatar
If I had the stock 19s, I would run 245/35/19 front and 265/35/19 rears. The 265s will fit fine on the 8.5" rim, but I would go no wider. The fellow above running the 265/30s is killing the stagger, and running a tire that is too small in outer diameter.
Lou
Old Nov 20, 2006 | 01:46 PM
j-velocity's Avatar
Lou
The diameter is about .5" smaller.
But the speedometer is off by about 1.5mph only.
Also why am i killing the stagger?
Old Nov 20, 2006 | 09:27 PM
lowrider's Avatar
245/35 ZR19 = 25.8" In Outer diameter
265/30 ZR19 = 25.3" In Outer diameter
265/35 ZR19 = 26.3" In Outer diameter
The above was taken from a Michelin PS2 Tire chart. The front OD should be from .5" to 1" lower in the front than the back. You have it the opposite way around. Your higher in front than the rear. The coupe is designed to handle properly with the stagger, and it's eletronics (VDC) are designed to recognize the stagger, and to protest when it's not there. I'm surprised your VDC is not acting up with your arrangement. The OD is not .5" off, but closer to an inch off in the rear. The front is fine. Also, you should have a large fender gap in the rear.
Lou
Old Nov 20, 2006 | 10:02 PM
kennyz424's Avatar
you wont have any problems with those tire measurements man!! =-)
Old Nov 20, 2006 | 10:52 PM
badtziscool's Avatar
I just replaced my rears with 255/35 19 RE050A. I think it actually looks better. The slightly lower profile enhances the stance just a little bit more. Haven't had the chance to take any pics just yet.
Old Nov 21, 2006 | 12:13 AM
sngpimpin's Avatar
sweeet post a pic! =) i wanna see!
Old Nov 23, 2006 | 06:47 AM
G-MAN (CANADA)'s Avatar
I have this setup on my sedan (235/35R19) and with my drop on Tein STechs it looks prety good, if your car isn't that low you might want to go with a 40 series tire to fill the gap a little more.
Old Nov 24, 2006 | 01:34 AM
GreenGoblin's Avatar
The goblin resurrection
you will have no probs
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nervseele
Jul 17, 2015 11:21 PM
mushu
Jul 15, 2015 03:55 PM
