Is 255/40/18 tire ok for stock rear rim?
Old Dec 10, 2006 | 02:55 AM
acerys's Avatar
I want to go a bit wider tires on the rear. My friends recommended 255/40/18 rather than 255/45/18 because the thicker sidewall would increase cornering instability. Is that true?
Old Dec 10, 2006 | 05:33 AM
nghiars's Avatar
just cuz the tire is wider in size does not mean the sidewall will be wider.. the wider tires should help cuz you ll have more rubber resulting in more traction but how much will 10mm help and other tire brands could also help as well.. i would do it just cuz i like meat on my wheels
Old Dec 10, 2006 | 09:52 PM
godmans's Avatar
Theortically, an increase in tire wall aspect ratio (or you can just call it height) will give a softer sidewall (assuming that you are comparing the same brand/type/model of tire), which is known to provide less conering stability.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
