M45 Sport Wheels
Old Dec 22, 2006 | 12:54 AM
Julie's G's Avatar
M45 Sport Wheels
I'm looking to buy the M45 19' Sport Wheels. ( The ones everyone keeps drooling over ! ) Now I was wondering what size spacers, if any, will be required if purchasing,
A. 2005 M45 Sport Wheels
B. 2006 M45 Sport Wheels
My G35 is a 2005, 4-door Sedan, Automatic, with the Luxury and Sport Packages- Meaning I have the 18' Sport wheels on My G35 now.
All help would be appreciated,
Thanks.
Old Dec 22, 2006 | 08:47 AM
aleok's Avatar
i got them on my coupe, i used 25mm spacers. the guy i bought them from tried fitting them on his sedan, and it didn't. so what the stock sedan offsets? 40 something? so i'd say 10- 15mm spacers would be good. the M rims offsets are 50mm.
Old Jan 12, 2007 | 05:40 PM
DenverG35X's Avatar
I've got a similar question. If I get the 10 mm or 15 mm spacers and put on the M45 sport wheels...is there going to be a problem if I switch back to my 17's?
I want to put the 19's on for the summer with high performance tires, and be able to switch to the 17's OEM's for winter driving here in Colorado.
Old Feb 3, 2007 | 11:54 PM
D To The G's Avatar
what kind of tire set up did u go with those M Wheels for your coupe
Old Feb 4, 2007 | 12:30 PM
kenchan's Avatar
if those are 50mm, you can probably fit a 30mm spacer up front
and 25mm on the rear for a nice tight fit. if the tires are on the
narrow side, do 25mm front and 20mm on the rear so that it
doesn't look weird.
kics should have those sizes.
Old Feb 5, 2007 | 01:29 AM
Triple8Sol's Avatar
I agree w/kenchan. If the offsets are, indeed, as high as 50, then you really want to run some 30mm spacers front/rear to make it sit right.
Old Feb 5, 2007 | 01:46 AM
G35Papa's Avatar
Thanks.
Since you have a SEDAN, I recommend running a 10mm spacer. This will ensure you clear the suspension and give more of a flushed look with the wheel. If I remember correctly, those 19's are 8" wide? If so, I would go with a 245/40 tire. Should be a good fit.
The larger spacers recommended above (i.e. 30mm) are for a coupe setup, not a sedan.
Old Feb 5, 2007 | 05:38 PM
kenchan's Avatar
sedan, go with the smaller spacers.
Old Feb 5, 2007 | 05:46 PM
JOKER's Avatar
CLUB MODERATOR
I got 25 all around
30 would look much better for the front, but rear is fine with 25
Still looks bad a$$
oh yeah I got 05 Coupe
Old Feb 5, 2007 | 10:19 PM
G35Papa's Avatar
^Dude, she has a sedan, not a coupe. She needs smaller spacers.
BTW, I have your avart as my current wallpaper thanks!
Old Feb 5, 2007 | 10:37 PM
Sportcoupe35's Avatar
5mm spacers for a sedan.
by the way there is no 2005 M45.
Old Feb 5, 2007 | 10:47 PM
D To The G's Avatar
So lets clear this up so if u have a coupe how big of spacers do i need in the front and rear and i also heard that having spacers can be somewhat dangerous
Old Feb 6, 2007 | 12:08 AM
kenchan's Avatar
if you use a spacer incorrectly they are dangerous... like forcing a 5+mm
spacer on stock stud lengths.
Old Feb 6, 2007 | 12:10 AM
D To The G's Avatar
where do i buy longer studs and i still need my question above answered thanks guys
