Difference Between the Hollow and Solid Sway Bars?
Old Nov 24, 2003 | 11:54 AM
dklau33's Avatar
I've read up on the the different sway bar systems out for our cars and it seems some of them are full solid while some of them have a hollow core. Is there any difference performance wise between the two designs? Logically I would think the hollow ones are not as stiff and not as strong as the solid ones. But perhaps the hollow ones are made up of a stronger metal which allows the hollow core without any degradation in strength? Basically, I'm interested in getting the Eibach sway bar kit which is of the hollow core design. Just wondering if there's any disadvantages to the hollow core design vs the solid design. Thanks.
Old Nov 24, 2003 | 11:55 AM
pestilence's Avatar
Re: Difference Between the Hollow and Solid Sway Bars?
I had the same question..but didndt have time to post and ask..
I was thinking solid would be better.. but I know nothing of the subject.. I was thinking about the Cusco sway bars
Old Nov 24, 2003 | 04:32 PM
socalg35's Avatar
The hollow ones are better because they are lower in weight. Check out Hotchkis.net. They are a well known company that specializes in hollow sway bars for American cars. They have a FAQ that I don't know how to attach.
'03.5 BS Sedan, tint, XM, GroundingGear, Premium, Willow, Zaino, etc.......<P ID="edit"><FONT class="small"><EM>Edited by socalg35 on 11/24/03 01:44 PM.</EM></FONT></P>
Old Nov 24, 2003 | 04:42 PM
culmination's Avatar
the strength between the two are almost the same. so the hollow one would be a better choice.
Friends don't let friends drive stock
Old Nov 24, 2003 | 04:50 PM
socalg35's Avatar
I actually just checked their site (WWW.hotchkis.net) and they show show the sway bars for $254 for our cars (coupe and sedan are the same price). That is for the front and rear. I used them on an Impala SS and they are nice!
Old Nov 24, 2003 | 08:33 PM
DEJim's Avatar
My cusco (solid) sway bars will arrive on 11/28. I'll weigh them and then weigh the stock (hollow) bars and post here...
It might prove to be a good weight to stiffness comparison. Others can post weights of their bars when they get them. It would be good data to add to gsedan35's swaybar info (see the "Sway Bars only?" thread).
Old Nov 25, 2003 | 01:51 AM
dklau33's Avatar
smcallis: I'd be interested to hear why the center portion of the sway bar has a smaller effect on the overall stiffness than the outer portion. Just can't picture why from an engineering standpoint.
Old Nov 25, 2003 | 02:23 AM
lets say there is a transverse load on solid bar. the bottom portion of the bar will be subjected tension while the upper portion of the bar will be subjected to compression. the mid point of the bar however are not subjected to any kind of load what so ever. so... solid.. or hollow it doesn't matter... the loads are carried at the outter portion of the bar.
Old Nov 25, 2003 | 03:35 AM
badtz's Avatar
my 350evo sway bars were 30lbs in shipping. so they can't be more than 30lbs. it's a solid bar.
Old Nov 25, 2003 | 06:02 AM
SixFive's Avatar
exactly what could one expect in handling chages and ride quality?
Old Nov 26, 2003 | 01:56 PM
dklau33's Avatar
So I'm guessing the consensus here is all things being equal (or close to equal, ie. stiffness) one would want to go with the hollow bar instead of the solid bar for weight savings reasons. But the question is does the weight savings for the hollow bars vs the solid bars have any noticable effects? Probably not since the amount of weight reduced isn't a whole lot. Correct me if I'm wrong.
Old Nov 26, 2003 | 04:55 PM
3point5SE_Auto's Avatar
RE: Weight reduction
you are looking for a cumulative effect, not an all at once effect.
Say you can save 100 lbs (pretty close at least) by going with an aftermarket exhaust from heads to tailpipe, then throw in savings from lighter wheels (as much as 50 lbs for all four wheels), factor in another 10-20 lbs from the sway bars, etc..... you get the picture it all adds up.
One downside to dropping weight. Too much reduction down low can raise your center of gravity. The above 180 lbs (6%) or so will merely offset the weight of the driver so you should be allright but extensive reduction under the car can move the center of gravity up too much. Wider tires (or larger dia. wheels) can offset this as well and maintain more contact patch between tire and ground.
Just remember this car is VERY well engineered and everything you do is a tradeoff, so plan on counterbalancing every mod with another. Great wheels and tires can make up for a lot of engineering changes.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Old Nov 27, 2003 | 09:45 PM
DEJim's Avatar
Re: RE: Weight reduction
Got the Cusco sway bars early. Haven't swapped them out yet, but:
Front: 12.5 lbs
Rear: 8.0 lbs
Total: 20.5 lbs
I'll post stock weights when I'm done with the install.
