Thinking about iForged wheels.
Old Dec 6, 2003 | 04:52 AM
  #31
bkchang79's Avatar
Re: Thinking about iForged wheels.
Just remember edretti, I got the iforged flux first. =)
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Old Dec 6, 2003 | 08:53 AM
  #32
Edretti's Avatar
haha bk! Dude I am really diggin your wheels. But you will see I get bored very easily. I'm already going on my second set of wheels and I bet I change them again next year. Anyway Tiji, you definitely want to stick with 35/30 set up for front and rears.
Edretti
2003 Infiniti G35 Coupe 6mt Loaded Brillant Silver
http://www.cardomain.com/id/edretti
Old Dec 6, 2003 | 01:02 PM
  #33
Triji's Avatar
okokok, I am stubborn. What about a 35 / 35 set up then? I just cant get it outta my head that the rear rubber would be thinner than the front. How much would that throw off the speed? Lol...
2004 Coupe, 5AT, Twilight blue / Willow int. Clear corners, Hypers. 18's, Aero, tint, Pemium.
Old Dec 6, 2003 | 01:19 PM
  #34
Edretti's Avatar
man...you are stubborn! :<)) Still don't think it will work. Remember, the rear wheels are a lot fatter then the front. Go back to page 1 of this post and look at the two pictures I posted of my front and rear wheel. See any difference? I doubt it.
Edretti
Old Dec 6, 2003 | 01:53 PM
  #35
Triji's Avatar
Whaaaaa. Your killn me here Edretti. Your ride looks sweet man, I cant tell from the pix tho... Do you have it lowered? and on 20's? I was noticing that TB in this thread had 35's in front and back. but if I went with the stagger of 8.5 and 10 with the rears width. The way I understand it is that I need less sidewell on the rears to keep the correct set up for the car? I am looking @ 19's as well and not 20's so in your opinion 35/30 is still the way to go?... Do me a favor and just hit me over the head with a brick, will ya man?
With that set up do ya look like a low rider with the front higher than the rear? or is there still a agressive lean to the car to the front?
Crap I ducked, get that brick again and give it another try..."WHACK" ... Thanks
Old Dec 6, 2003 | 02:31 PM
  #36
Edretti's Avatar
WHACK! Again thanks for the compliments. Yes I still think you need to go with that set up(35/30). Believe me that the car doesn't look higher in the front. You don't want to have the back sit higher anyway because then that will affect your suspension. No my car isn't lowered. It just looks that way because of the 20's. If I had 19's I would lower it.
Edretti
Old Dec 6, 2003 | 03:12 PM
  #37
Triji's Avatar
WHACK-WHOMP!!.... Ok that worked. Thanks for all you help Edretti. Now you got any ice for the lump on my head? Now since you show cars, whatcha think of silver callipar paint on my AT breaks on a TB coupe?
Old Dec 6, 2003 | 05:57 PM
  #38
mkuryla's Avatar
Now to add to the confusion.................mine are 19" car is lowered and the tires are 35 profile front and back, and yes there is more sidewall height on the back tires...........I like it just how it is, only reason I didnt get 20's and go with edretti's
setup is cause the roads around here suck.
Robin
04 G35 Cp 6MT - TB 19" Iforged Aero's 245/35/19 & 285/35/19, Borla headers & Exhaust, Test Pipes, Eibachs, Nismo Sway bars, Prochager(now its fast!!!!)
Old Dec 6, 2003 | 06:31 PM
  #39
Triji's Avatar
ROBIN!!!!!!!!!!!!. Damn Girl, I was noticing yours but just didnt want to say anything cause I thought I had it all figured out. BAH!! Is your Speed still on with that set up and is the handleing still just as tight as stock? with very little body roll "pre-sway bars"?
Old Dec 6, 2003 | 07:01 PM
  #40
G35Art's Avatar
Actually the 275/35 is closer to the stock wheel diameter than 285/30. Use athe tire calculator to compare. I contemplated this same issue and decided on the 275/35 because of this site
http://www.1010tires.com/TireSizeCalculator.asp
Old Dec 6, 2003 | 07:37 PM
  #41
mkuryla's Avatar
But the 285 looks better on a 10" rim
Might even try a 295/30 19 and roll the fenders once I get another set of wheels.
Robin
Old Dec 6, 2003 | 09:57 PM
  #42
Edretti's Avatar
I have to agree with Robin. I've seen the 275 and it doesnt even come close to the look the 285 gives it. There is definitely room for a 295. I'm contemplating it on my next set of wheels.
Edretti
Old Dec 7, 2003 | 10:51 PM
  #43
Triji's Avatar
Ok, got it... Going with probably 20" 8.5 - 245x35 front and 20" 10 - 295x30 or 285x30 "depending on space" rear IForged Aeros FS {forged series}
Thanks for all the help and input.
2004 Coupe, 5AT, Twilight blue / Willow int. Clear corners, Hypers. 18's, Aero, tint, Premium.
Old Dec 7, 2003 | 11:55 PM
  #44
damen's Avatar
are you saying that my 275 don't look good eddy? i'm the one that started all of this. and don't you forget it. j/k hehehehe but, really i will go with 285 next time.
robin your car looks hot. i'm loving that blue but, not more than the IP. hehehehe
Old Dec 8, 2003 | 12:22 PM
  #45
malx's Avatar
Anyone know how much our stock rims weigh? PM ME!
Thanks - Joey Avino
