Tires Rubbing in the rear
Old Mar 1, 2007 | 08:48 PM
Bmurray's Avatar
I have a 04 G coupe with 20x10 axis shines. The tire are rubbing the fenders on the outside of the tires and I need to get this fixed. I know I have the option of rolling the fenders but I wanted that to be my last option. Let me know if anyone is running this setup and experiencing the same problem. If so, what you did to correct this issue.
Thanks
Brian
Old Mar 11, 2007 | 04:03 PM
Endless Shock's Avatar
Welcome to the board... Thats nothing a good fender roll wont solve...
Old Mar 11, 2007 | 04:17 PM
redlude97's Avatar
increase your negative camber or run narrower tires, those are you only two other options if you don't want to roll
Old Mar 11, 2007 | 04:19 PM
BadBoy06's Avatar
what he said^^^
Old Mar 11, 2007 | 04:33 PM
Bernz's Avatar
That's weird I just upgraded to 20 x 10.5 in the rear and i have no rubbing issues . . . but i still have to get an alignment done.
Old Mar 11, 2007 | 04:40 PM
Nismo G's Avatar
What size tires are you running?
-sean
Old Mar 11, 2007 | 04:47 PM
redlude97's Avatar
All depends on offsets, unless you have the same offsets and tires as him, your setup doesn't really mean anything
Old Mar 11, 2007 | 04:49 PM
Bernz's Avatar
20 x 10.5 285/30/20 with 350z H-Techs . . . Lip is 76mm i think the offset is +40
Old Mar 11, 2007 | 04:50 PM
redlude97's Avatar
offset?
Old Mar 11, 2007 | 10:03 PM
cutiewolf's Avatar
roll the fender
Old Mar 12, 2007 | 05:11 PM
Bmurray's Avatar
Fenders
I took the car to a local wheel shop who claims that have a fender rolling machine. After about 2 hours, they called me and said that they could not roll the fender anymore die to the paint cracking. I went and picked up my car and rolled the fenders myself with the instructions from the site and it came out perfect. No more rubbing. Now it's time for a set of lowering springs. I can't go too much due to the size of the wheels. Anyone have any suggestions on which springs? Thanks for the help guys.
Old Mar 12, 2007 | 05:13 PM
redlude97's Avatar
So did the paint crack or not?
Old Mar 19, 2007 | 09:22 PM
Bmurray's Avatar
fenders
The wheel shop actaully cracked the paint. However, it did not when I used the blowdryer and the PVC. Should've saved myself the aggrevation and did it myself the first time.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
wuppiedog
Aug 7, 2015 11:16 AM
jjohns2711
Aug 5, 2015 08:58 AM
Soumilg
Jul 18, 2015 12:33 PM
