Another winter tire question...
Old Dec 5, 2003 | 06:33 PM
nthnbutaGthang's Avatar
this site says you can get just 2 snow tires if you have rwd.. http://www.discounttiredirect.com/di...odeIndex=70304 is that correct? will it be that much worse than 4 snow tires?
Old Dec 5, 2003 | 08:17 PM
ryoken's Avatar
Re: Another winter tire question...
The problem with only 2 is that your front tires are the ones that steer and do most of the braking. By putting two snows on the rear (drive) wheels, you've now created a machine that can go better, but can't turn or stop better. Not a good combination in bad weather conditions.
You don't want to put only 2 snow tires on the front, as then you can get into situations where the rear looses traction and you'll spin out, and there's nothing the VDC system can do to save you.
Old Dec 5, 2003 | 11:33 PM
G35Gnome's Avatar
Ryoken is right, listen to him Get all 4.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Dec 6, 2003 | 07:59 AM
now the only problem seems to be finding anywhere that has 4 tires...
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
