Help!! Will 25 front and 30 back offset FIT for 2003 g35c?
Old Mar 8, 2007 | 03:42 PM
netcbc's Avatar
hey was looking at some 19" nismo's offset is
2 Front Rims 19" x 8.5" +25 OFFSET
2 Rear Rims 19" x 9.5" +30 OFFSET
will it fit my 2003 g35c
will i need spacers??
Old Mar 8, 2007 | 03:43 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
it'll fit but it might be a little tucked in, you would only need spacers if you want the wheels completely flush with the fenders.
-GP-
Old Mar 8, 2007 | 03:50 PM
Calvin's Avatar
Overglorified Altima
itll be a lil tucked.
Old Mar 8, 2007 | 03:56 PM
Hi-TechG35's Avatar
You'll be alright. I am running +25 all around on a 20x9 in and 20x10.5
Old Mar 8, 2007 | 04:43 PM
netcbc's Avatar
thanks for the input guys, so if it's tucked, will tires ever get punctured from the sidewall/fender?
Old Mar 8, 2007 | 04:45 PM
redlude97's Avatar
I'm running 8.5+20 and 9.5+30, and its sticks out slightly more than stock. Running 285's in the rear with a drop, I don't have much clearance with the fender lip, and going much lower on the offset and I'll rub without a roll. That being said, I'm planning on rolling the rear, and adding a 15mm spacer on the front and a 20/25mm spacer on the rear depending on how much clearance I gain after rolling
no, that just means that they will be more towards the suspension and further away from the fender.
-GP-
Old Mar 8, 2007 | 04:48 PM
Pratik's Avatar
Moderator
Moved to wheels and tires and since I have those same wheels they will be a little tucked in but some spacers will make it look hot.
Old Mar 9, 2007 | 09:42 PM
papiloco21's Avatar
theyll work fine
Old Mar 10, 2007 | 01:31 PM
netcbc's Avatar
thanks everyone once again
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
joedaddy1
Jul 28, 2015 02:58 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
apintojr
Jul 23, 2015 10:52 AM
realtalk21
Jul 20, 2015 09:07 AM
