Recommended PSI
Old Dec 9, 2003 | 03:24 PM
SilverG35ny's Avatar
Recommended PSI
Hi,
My coupe came with 17" rims and tires which I replaced with the 18" performance tires. What is the recommended PSI for the 18 inch rims and tires? Usually it says it on the inside of the door but since I upgraded I dont know what to keep the tire pressure at. Anyone with the performance package tires with an answer for me would be greatly appreciated. Thanks
Old Dec 9, 2003 | 03:52 PM
G35Gnome's Avatar
Re: Recommended PSI
It also should say on the tire sidewall.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Dec 9, 2003 | 05:53 PM
gsg's Avatar
gsg
Re: Recommended PSI
The recommended tire pressure for the 18" Pilot Sports on the coupe is 35 psi for all 4 tires - per the door plate and the owners manual.
I have been running this pressure and it seems OK. You can probably run a little less for a smoother ride but I don't know how it affects handling.
Old Dec 9, 2003 | 06:56 PM
Re: Recommended PSI
Thanks for the information gsg I appreciate it.
Old Dec 9, 2003 | 11:23 PM
AirSplat's Avatar
Re: Recommended PSI
yeah, i agree. I've tried lots of different tire pressures and every source said different things, but 35 seems to be a good pressure. But make sure that's the pressure at cold temp.
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Old Dec 10, 2003 | 12:04 PM
Saridi's Avatar
Re: Recommended PSI
does anyone know what is the recommended tire pressure for 17" snow tire?
Grounding Kit
GruppeM Intake (ETA: late Nov... [img]/w3timages/icons/frown.gif[/img])
Fujitsubo Cat-back + Y-pipe (On order)
19" NISMO LM GT4 (On order)
Old Dec 10, 2003 | 04:45 PM
Msedanman's Avatar
O.F. Administrator
Re: Recommended PSI
Saridi, I keep mine at the same as the summer tires, (35) and they seem to be fine. Just make sure you don't exceed the max. recommended pressure (cold) which you'll find on the sidewall.
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
Old Dec 10, 2003 | 04:48 PM
wreck's Avatar
Running for his life!!
Re: Recommended PSI
From what information i've gather. The air pressure remains the same wether you have 17's, 18's, 19's, or 20's. Use the recommended psi (on your door) for normal driving.
G35C 6MT / AMG E55
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
