G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   OEM 19's on, now brake problems? (https://g35driver.com/forums/wheels-tires/147666-oem-19s-now-brake-problems.html)
2001Z71 Mar 27, 2007 08:11 PM
Hey all, I just got a set of OEM 19s put on my car along with brand new 255/40 (rear) and 235/35 (front) Falken 452s at Discount Tire. On my way home (45mins) I noticed that the brakes felt weird. The pedal is pretty stiff and when I brake moderately hard the pedal has a slight feeling like when the ABS activated.
Anybody know what could be happening?
BadBoy06 Mar 27, 2007 11:27 PM
can you see any clearance issues? best to not mess around
if brakes are feeling weird..get it looked at ASAP;)
RichardxG35 Mar 27, 2007 11:29 PM
i think you need to bleed the brake oil
2001Z71 Mar 28, 2007 04:15 PM
anyone else?
redlude97 Mar 28, 2007 04:23 PM
try swapping back to your stock wheels and seeing if that corrects the problem.
2001Z71 Mar 28, 2007 04:31 PM
well, I had some 19s on there before so I dont think that would be it, i dont have the stockers...
I guess Ill take it to a brake place
nghiars Mar 28, 2007 05:57 PM
maybe it has nothing to do with the wheels or tires.... get em checked out man ASAP
2001Z71 Mar 28, 2007 07:07 PM
Its just weird because they were fine before I went to Discount, then the second I drove it off the lot and used the brakes I noticed how weird they felt (less than 1/8 mile)
I took it to Meinake (sp?) today, they said come back tomorrow. Took it to Discount Tire and they checked the torque of the lugs out and made sure the 8.5 were on the back and the 8.0 were up front. I drove it around after that and brakes still feel weird :(
G35 Mass Mar 29, 2007 02:20 AM
Did they put the wheels on with an impact wrench? May have f'ed your rotors... I think that's how I destroyed my left-rear one... over-torqued the lugnuts....
2001Z71 Mar 29, 2007 10:40 AM
I think they did... How can I tell?
2001Z71 Mar 29, 2007 12:45 PM
Well, I was driving to school this morning, and when I was on the highway the following dash lights came on:
ABS
SLIP
VDC OFF
I really hope my rotors arent messed up.
G35octane Mar 29, 2007 01:22 PM
if the lugs were over torqued you might have warped the rotors which is why you would feel the pulsating effect on the brake pedal, as to the pedal feeling STIFF. THAT COULD BE A BIG PROBLEM, NOT SAYING IT IS BUT YOU MUST GET IT CHECKED.
2001Z71 Mar 29, 2007 04:10 PM
Taking it to the Dealer tomorrow morning to get it checked out :)
Thanks for the help guys!
2001Z71 Mar 30, 2007 04:40 PM
Infiniti techs said that my brake problems are due to the new tires:
255/40/19 on the rear
235/35/19 on the front
Sound legit?
Jeff92se Mar 30, 2007 04:46 PM
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
255/40-19 4.0in 13.5in 27.0in 84.9in 746 0.0%
235/35-19 3.2in 12.7in 25.5in 80.0in 792 -5.8%
Looks like it. The two tire's diameters should be within about 5% of each other. Looks like you are over that. So the vdc thinks you are constantly slipping therefore appling the brakes.
© 2026 MH Sub I, LLC dba Internet Brands
