Quick Q: Coupe wheels on a sedan
Old Mar 29, 2007 | 10:25 PM
Homeslice's Avatar
Good evening,
I did a search through the last year of posts but I didn't see this answer. Sorry if it is a repeat or a very simple question but I want to make sure.
I am looking to replace my OE 2003 17's on my sedan with the newer 17 or 18 inch 7 spoke wheels. I have seen some of the couple wheels for sale and it looks like all 4 wheels are 18x8 but the tires are 225/45/18 Front and 245/45/18 Rear.
Is that stagger ok on the 03 sedan?
Thanks!
Old Mar 29, 2007 | 10:30 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
They will fit fine w/no problems with the stock coupe tires if you're not lowered. IF you are lowered then you will need to go with a lower profile in the rear to keep from rubbing. You're eventually going to need new tires so when you do, i'd go with a 235/45/18 or 245/40/18 all around so you can rotate the tires.
-GP-
Old Mar 29, 2007 | 10:33 PM
Homeslice's Avatar
Wow,
Thanks GP! Quick and informative response.
Have a good evening!
Old Mar 29, 2007 | 10:35 PM
Originally Posted by Homeslice
Wow,
lol, that's what were all here for, to help eachother out. Plus, i have nothing else better to do than be on driver when i'm bed riden with the flu!!
-GP-
Old Mar 29, 2007 | 10:41 PM
Homeslice's Avatar
Yikes! I hope you feel better soon!
Old Apr 20, 2007 | 01:20 AM
dahkyne's Avatar
how about if your sedan is on unrevised Z springs? will the rears still rub on stock tire sizes?
-GP-
Old Apr 20, 2007 | 01:43 AM
ttrank's Avatar
Grocery getter
They might. What is the offset on those rears?
Worst case just roll or cut your rear fenders.
Old Apr 20, 2007 | 01:49 AM
dahkyne's Avatar
ttrank-
18" OEM coupe rear wheels are +33; fronts are +30... im more concerned about the rears than fronts
ive seen sedans with Z springs and coupe wheels, but i just dont see that offset working with the z susp and coupe wheels AND the stock tire size which i have on my current set of wheels... want to know before i actually pickup a set...
here's my car as it is now on 18x8.5 +45 all around...
http://www.box.net/shared/hcstraaf0b
Old Apr 20, 2007 | 02:41 AM
ttrank's Avatar
Grocery getter
A +33 18x8.5" with a 245/45 should fit without rubbing issues.
Old Apr 20, 2007 | 02:47 AM
dahkyne's Avatar
thanks... i think im just gonna pass on the purchase of coupe wheels for now... i really want my 19" volks so the $ saved will just go toward that... and i know for sure the 19s wont rub with the offsets im going with...
Old Apr 20, 2007 | 03:15 AM
ttrank's Avatar
Grocery getter
Good call. Go for what you want in the long term.
Old May 22, 2007 | 11:23 PM
03G35SPORT's Avatar
Ok i have been looking into this also since all for wheels are 18x8 with a offset 0f 30mm and why are the rear tires a 245-45-18 and the front are 225-45-18.why cant all four be 225-45-18 . are the rear wheels any wider. the reason I ask is because I have for 225-45-18 tires and are still like new so I am seeing if I can do theat instead of buying new tires.
Old May 22, 2007 | 11:24 PM
They are staggered for the coupe. All the wheels are the same width and offset. You can use 225/45/18 all around no problem
-GP-
Old May 23, 2007 | 07:52 AM
03G35SPORT's Avatar
sounds good thanks for the input
Old May 23, 2007 | 10:46 AM
ttrank's Avatar
Grocery getter
Yeah you can run 225's all around.
