Will 19 x 9.5 40mm or 45mm fit?
Old Dec 17, 2003 | 11:05 PM
Derek173's Avatar
Or Do I have to get 19 x 8.5 35mm ?
Non brembo 5AT
Old Dec 17, 2003 | 11:36 PM
AirSplat's Avatar
Re: Will 19 x 9.5 40mm or 45mm fit?
I'm assuming the 40 mm and 45 mm number you're referring to is the second number in the tire size.
I'm sorry, but I believe the second number is a percentage of the first number. Therefore your question in incomplete. You actually need to state the width of the tier, like 240 or 245 or 230 or something like that, then the second number is a percentage of that number. So, we'll need to know the first number of the tires your considering.
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Old Dec 18, 2003 | 12:05 AM
Derek173's Avatar
I thought that was offset?
Old Dec 18, 2003 | 01:13 AM
narkotic's Avatar
45 ofset is usually a honda offset... you wanna be down more in the low 30's to mid 20's...
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Old Dec 18, 2003 | 05:16 AM
RaySur350GT's Avatar
Is this going on a coupe? If it is then, no you don't want those rims on a G35C. The offset is too high which will make the rim really tucked in the wheel well, think of a skate board or a train. For after market rims, you want it to be in the 20s to 30s offset. The stock 18" G35C rims are +30 offset already.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Dec 18, 2003 | 04:30 PM
atlgfreak's Avatar
i have offets of 19 in the front and 29 in the rear. they are really aggressive and sit the wheels right at the edge of the car.
2003 G35 Coupe, 6sp, Laser Red, Willow
1992 Cherokee Sport Red (daily driver)
Old Dec 18, 2003 | 07:40 PM
2003z's Avatar
yes they will work. Using this websites calculator, http://toy4two.home.mindspring.com/offset.html the difference from a stock 18 is this:
Your new wheel will have the following chracteristics:
The clearance from stut housing to the inside of the wheel will be 29mm LESS
The outside edge of the wheel will EXTEND an extra 9mm,
(that is with a +40, it WILL NOT be tucked at all, but +45 will only extend 4mm, and be virtually like stock, and may not clear the strut housing)
2003 350Z & 2003 G35c
www.350zfrenzy.com
www.g35frenzy.com
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
