Will 10mm-15mm push this to the edge?
Old Apr 9, 2007 | 03:25 PM
sen_jen's Avatar
Meatshake Enterprise
Of course, we are talking about a tight roll though, where you are bending the lip almost 90 degrees vertical. This is where heat won't necessarily save you from paint cracking. I've done enough research to know that doing so is the most dangerous part of the whole procedure, the paint when its warmed up can stretch quite a bit, but 90 degrees is getting towards the limit of safety when it comes to cracking
i've been in autobody/paint for a while. my brother owns one of the best, if not the best custom autobody/paint shops on island.
Old Apr 9, 2007 | 03:48 PM
redlude97's Avatar
And your point is? I was agreeing with you, just adding to it
Old Apr 9, 2007 | 03:54 PM
sen_jen's Avatar
oh, dam navy computers suck azz. my point is you're correct on the added change you've provided.
Old Apr 9, 2007 | 05:09 PM
ATL_Red_G35's Avatar
so I'm going to add 15mm spacer
Shave the fender wells
And flare it out a bit
Any things to concern about in the long run?
Old Apr 9, 2007 | 07:13 PM
redlude97's Avatar
If you are going to flair the fenders, be ready for a repaint, and make sure a a fender rolling tool is used to get the flair even.
Old Apr 9, 2007 | 07:54 PM
sen_jen's Avatar
good job on the "flare" of fenders. many people pull their fenders to achieve the extreme labia sized wheels, and the super vip look.
Old Apr 9, 2007 | 08:05 PM
redlude97's Avatar
Its definetly going to be unique, not sure how its going to look on the G as it has a pretty wide body line that runs around the fenders that you'll have to smooth out somewhat. I've personally only seen it done on 240's and SC's, but be sure to post pics when its all done
Old Apr 9, 2007 | 11:57 PM
I don't think I'm going to "flare" flare it... May be push the edge out a tiny bit, say 3-5mm at most...so it's not really a big flare...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mbe32
Nov 13, 2015 11:09 PM
Adon
Sep 22, 2015 03:56 PM
