Offset Question PLEASE HELP
Old Apr 18, 2007 | 12:29 AM
alphanumeric818's Avatar
i purchased sevas s-star 19x8.5 n 19x9.5 25 offset all around for a 2003 coupe with 17's
do i need spacers?
what do i do about that extra stud in the front hub it's preventing me from installin my new rims?
Old Apr 18, 2007 | 12:51 AM
nghiars's Avatar
the wheels will be fine all around... take the extra bolt off in the front.. it will be fine
Old Apr 18, 2007 | 01:12 AM
nooooorb's Avatar
do i need spacers?
Yeah, just take off the bolt(s). They're just to cover the tapped hole which is used to remove the rotors just in case they get stuck.
As far as spacers, you don't really need them. Your offsets are perfect the way they are now. If you want to use spacers, 5 mm should do nicely.
Old Apr 18, 2007 | 01:24 AM
Justin@WestCovinaNissan's Avatar
Also the thing about spacers is if you put spacers any thicker than 5mm you will need extended studs or bolt on spacers.
If you want the wheels to sit more flush, spacers are recommended. If thats not important to you then you should be fine.
Which brakes are you running?
Old Apr 18, 2007 | 03:38 PM
stock brakes no brembo's...
Thanks!!! for all your help...finally sum1 answered my question...
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
