Wheel Size Question for Sedan
Old May 4, 2007 | 04:34 PM
bios2k's Avatar
Hi, Every one tell to me that I should choose 19'' wheel
I finaly found a Wheel that I like
Now, I want to check if it will fit correctly my 2003 Sedan
it's 19'' x 8'' with 40mm offset
I will put 245/40/19 tire.
Is there any rubbing with this kind of config.
For the moment Im on stock spring.
but Will install Z front and coupe rear.
Thank you!
Old May 4, 2007 | 04:38 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
those will work perfectly, you wont have any problems even when you're lowered.
-GP-
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
Detailed Image
Jul 24, 2015 12:31 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
