Need help ASAP
Old May 4, 2007 | 10:31 PM
usingthejohn's Avatar
Need help ASAP
hey guys, if you saw my thread in the picture share forum, you'd know that i just dropped my car w/ some Ark coilovers, so obviously they would have to remove the wheels to install the parts.
Here's my problem: ever since the install, the lugs on the front drivers wheel keeps coming loose
I took it back to the shop (i was only a block away, when i noticed the wheel shaking really bad, not to mention a very obvious knocking/thumping sound from said wheel), and they retorqued all the lugs on each wheel...i forgot how much they torqued it down to, in the 100s or so??? BTW: This happened yesterday afternoon.
fast forward to today, the same thing happened again, to the exact wheel. I just tightened it as much as i can (i don't have a torque wrench, so i don't know how tight they are). My question is exactly why is this only happening to this wheel, and why is it still happening? I don't want to be driving 70mph on the freeway and have this happen.
thanks, JOHN
Old May 4, 2007 | 10:43 PM
Andy2434's Avatar
Wow . . . I have no idea what might be causing the wheel lugs to loosen on their own. The issue is isolated to only the one wheel, so you should check the lugs, wheel studs and that particular wheel for problems. Personally, I would not be driving my car until the issue was resolved, if that situation presented itself.
I trust you find a quick resolve to this potentially very dangerous problem. Good luck!
Old May 4, 2007 | 10:45 PM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
I had the exact same problem in the same wheel. Found out that the wheel studs were striped at the end just a few threads and the nuts weren't grabbing on all the way had them all replaced and everything s back to normal for about 3 months now.
Old May 4, 2007 | 10:46 PM
i hope so too. The weird thing is that i was driving around on these same wheels for about 3 weeks, with no problem whatsoever. the problems started after i lowered the car. Think it might be stripped bolts, or maybe it needs to just be torqued down again?
Old May 4, 2007 | 10:48 PM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
Well if they torqued it down b4 and the problem came back. Id check your studs. And take it from there.
Old May 4, 2007 | 10:49 PM
nghiars's Avatar
they overtorqued them it should be around 80-85 lbs
Old May 4, 2007 | 10:51 PM
thats what i'm thinking. how much did it cost to replace the bolts?
Old May 4, 2007 | 10:53 PM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
i just bought the bolts and did it my self. took me about 20min to do all 5 and bolts cost me about 10$ i believe from kragens. If you go to a shop your probably looking at about 50$ for everything or so.
Old May 4, 2007 | 10:56 PM
GEE35FX's Avatar
Good point, if they really did overtorque them and threads could be stretched or fudged up. It might be a good idea to replace the studs.
two final questions: are these bolts a universal size, or are they vehicle make/model specific? And how easy of a DIY job is this?
thanks for your help
John
Old May 4, 2007 | 10:59 PM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
i just went in and requested bolt they looked it up on the comp and gave me those. They seem to be working dam fine so ya. And its just A LOT of pounding with a nice strong hammer.
Old May 4, 2007 | 11:13 PM
SOCOOL's Avatar
It's either going to be the lugs or the studs. I would start with the lugs first, it's less money for ya.
If this happened when you got lowered it was prob the dudes when they took the wheels off and put them back on.
I would take care of this real quick.
Old May 4, 2007 | 11:17 PM
gary c's Avatar
Defective Stud..........
Can we assume you had the coilovers installed? Someone using a impact gun
did a number on your studs.....just have them replaced. Once this is corrected don't let anyone install your wheels with anything but a torque wrench at 85 lbs. Impact guns are also the main reason brake disc's are
warped.....same problem
Old May 5, 2007 | 12:21 AM
yeah, i had them installed....no tools + home remodeling = no garage space whatsoever.
So I guess i'll go get some studs tomorrow and go to my mechanic to have him put the studs in. would it be wise to get some new lugnuts while i'm at it?
Old May 5, 2007 | 02:53 AM
ttrank's Avatar
Grocery getter
It can't hurt but my money is on the studs.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
