I bought this ADRs by mistake, should i keep it or sell it ?
Old May 18, 2007 | 12:26 AM
GTT's Avatar
GTT
G35 Twin Turbo
I bought this from eBay by mistake. The question is should i keep them?
If 9.5" can handle 285 in the rear i think i will do it. what about the offset, is it gonna be good for my car.
http://cgi.ebay.com/ebaymotors/19-Ri...ayphotohosting
if anyone has the same wheel, please post picture.
Thanks
Old May 18, 2007 | 12:43 AM
GTT's Avatar
GTT
G35 Twin Turbo
some please help ?
Old May 18, 2007 | 12:58 AM
(>")> G35's Avatar
They'll work, the offsets are a bit conservative, but they'll work...also you can put a 285 on the 9.5"
Old May 18, 2007 | 01:00 AM
NonAme's Avatar
those look niice
should keep
u been a busy boy on ebay havn't yall.
saw your recent activaties
u spending alot of $$$
Old May 18, 2007 | 01:18 AM
GTT's Avatar
GTT
G35 Twin Turbo
Originally Posted by NonAme
those look niice
should keep
lool yeah
got agreat deal on RPS clutch and flywheel
Old May 18, 2007 | 01:24 AM
GTT's Avatar
GTT
G35 Twin Turbo
what do you mean by a bit conservation?
Thanks
Old May 18, 2007 | 01:31 AM
nooooorb's Avatar
Thanks
He means that with a +35 offset, the wheels/tires will be a bit tucked into the fender. If you want the wheels/tires to be flush with the fenders, your offset should be in +18 to +25 range.
I'd say keep the wheels and get some 15mm spacers. Those should do nicely...
Old May 18, 2007 | 01:42 AM
BlackOutG's Avatar
^ +18 is the best foir the rear + 17 in the front
Old May 18, 2007 | 01:46 AM
GTT's Avatar
GTT
G35 Twin Turbo
If I added 15mm spacers, that should bring it to +50 offset. I really don't know , or 15mm - 35 =20 ?. I want my wheels to be flush like you said .
Old May 18, 2007 | 01:58 AM
(>")> G35's Avatar
With spacers you subtract. The higher the offset the more tucked in it will be, so adding spacers push them out, therefore lowering the offset.
Old May 18, 2007 | 02:01 AM
GTT's Avatar
GTT
G35 Twin Turbo
Thanks for the info
nooooorb's Avatar
Yeah. What he said is correct...
It will be +35 - 15mm = +20.
Old May 18, 2007 | 02:03 AM
RocketG35's Avatar
Why do I bother to DIY???
When you add spacers of that amount, make sure you get longer studs. There are some (project Kics) that come with new studs. If you don't add the studs, you won't have enough thread to securely hold your wheels on. The Kics spacers can get quite pricey...($2-300 I think).
BTW - I've never seen those before...very interesting and could look nice one your car.
GTT's Avatar
GTT
G35 Twin Turbo
Thanks noooorb
Old May 18, 2007 | 02:06 AM
GTT's Avatar
GTT
G35 Twin Turbo
you mean like this
http://cgi.ebay.com/ebaymotors/Kics-...ayphotohosting
