Wheel size recommendations.
Old Jun 16, 2007 | 12:52 AM
stabanito's Avatar
Hey I was just wondering what tire size you guys recommend for 19 x 9 1/2 rims for the rear.
Thanks!
Old Jun 16, 2007 | 01:04 AM
6MTFTW's Avatar
275/35/19
-Jerome
Old Jun 16, 2007 | 11:30 AM
madscientist's Avatar
Originally Posted by 2A656
275/35/19
-Jerome
i'm running that on my stock 19's on the rear which are 8.5" wide.
you might want to try something a little wider.
Old Jun 16, 2007 | 11:38 AM
6MTFTW's Avatar
Well, seeing how according to most tire manufacturers recommend a 9.5" to 11" wide wheel for a 275/35/19, that's why I recommended a 275/35/19. It almost looks a little too wide for the wheel if you look at the sidewall. However, its barely noticeable. Also, the overall tire diameter is very close to stock. Therefore you're less likely to have any problems with VDC or ABS.
-Jerome
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
