Will these wheels fit?
Old Jun 19, 2007 | 12:21 AM
JaxShawn's Avatar
Yes I've searched, however....
I'm looking to buy some 5zigen fno1r-c 18x 8.5 + 30 fronts
and 18x 9.5 +22 rear
will these wheels fit and what size tires should I run?
Will I need to roll the fenders?
Any insight is appreciated. Thanks
Old Jun 19, 2007 | 12:27 AM
EEjiggapin0's Avatar
do you have a coupe or sedan?
if you have a coupe, they will definately fit, not too sure for sedan since I haven't searched about sedans
Old Jun 19, 2007 | 02:16 AM
JaxShawn's Avatar
I have an 04 coupe, what about tire size the pkg deal comes w/ 265's I'd rather have 275's any problems w/ those?
or what size tires do you recommend.
Old Jun 19, 2007 | 02:21 AM
19x8.5 you can go with 245/35/19
19x9.5 you can go with 265/35/19
I say you reconsider your front offsets though, you can have a more aggressive offset than +30 in the front
Old Jun 22, 2007 | 01:02 AM
JaxShawn's Avatar
# 18x8 5x114.3+48mm
# 18x9 5x114.3+50mm
What about that set up or is the off set way out?
obender66
18 Inch
Mar 13, 2016 12:20 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
JaeXL
Aug 4, 2015 07:43 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
