Just got TE37's in today...whats the silver ring?
Old Jun 26, 2007 | 11:27 PM
shocktech's Avatar
Hey,
Just got my TE37's in today...STATUS gave me what I think are the hubcentric rings? Do I need these on my 2004 5AT coupe? If I do, whats the process to put them on?
Thanks for the help in advance, pics to follow
Old Jun 27, 2007 | 02:14 AM
Tarheel's G's Avatar
I think they are used to relieve pressure from the wheel studs, and to help with vibrations. I'm not using any with my wheels and have no problems.
Edit: You might need to ask if the wheels are hubcentric or not????
Old Jun 27, 2007 | 02:15 AM
helldorado's Avatar
They're hubcentric rings. Yes, you do need them. Your wheels are a 73.1 center bore, your hub is 66.1 mm across. It centers your wheel on the hub, keeping lateral stress off the studs. Not using them, puts lateral stress on your studs and doesn't center your wheels, which can lead to vibration or even worse, shearing of a stud!
Putting them on is easy. Push them down by hand around the hub until they're flush. If you need to, use a mallet or very lightly with a hammer. You want to try to avoid damaging the edge. Makes it harder to get your wheels over them.
Old Jun 27, 2007 | 02:22 AM
superdds's Avatar
^^^+1. use them...that's why they sent them to you.
Old Jun 27, 2007 | 06:13 AM
aleok's Avatar
i tried for the longest time to put them on, slides over the hub, but won't for the life of me fit into the rim. i gave up, and didn't put them on.
Old Jun 27, 2007 | 10:04 AM
shocktech's Avatar
Ok cool, and these are aluminum, I read that its better to have ABS ones because of the corrosion that will occur making it a pain in the *** to get the wheels off..is that true? Is there anything I can put on the aluminum rings to make them less likely to corrode?
Old Jun 27, 2007 | 10:12 AM
superdds's Avatar
i've had aluminum rings for my last two sets of volks...no problems here.
Old Jun 27, 2007 | 10:22 AM
shocktech's Avatar
My only concern is that I live on Connecticut and I get more precipitation here than in Cali...
Old Jun 27, 2007 | 10:42 AM
superdds's Avatar
i'd give status a call to confirm
Old Jun 27, 2007 | 10:43 AM
helldorado's Avatar
I have aluminum rings. Never had a problem with getting the wheel on or off, though they can be tougher to get off the hub. Its typically the hub where they get stuck, not the wheel. Then you'll just need a screwdriver or something to pry it off, WD40 or some sort of other rust breaker helps. If you gouge the edge of the ring, you can smooth it down.
Old Jun 27, 2007 | 11:53 AM
shocktech's Avatar
Oh well in that case...thats not that bad. The other thread made it seem like they would basically weld themselves onto the wheel/hub haha...ok well once I get my Kics R26 lugnuts in, ill put them on
Old Jun 27, 2007 | 06:01 PM
aleok's Avatar
mine came with plastic ones.... from status...
Old Jun 27, 2007 | 06:31 PM
shocktech's Avatar
I got mine from Status too and they are aluminum
Old Jun 29, 2007 | 05:15 AM
panda007's Avatar
aluminum > abs. you want a wheel fitment that's snug and just right onto the hub. plastic ones do not seat in securely, imho. i had some plastic gorilla ones and they did not relieve any vibrations as aluminum wheel hubs would.
the aluminum will not corrode... it's the rust on the hub that'll grip onto the rings.
Old Jun 29, 2007 | 05:51 AM
absolutg's Avatar
workin...
apparently volk is sending out aluminum rings according to rick @ status...
