Eibach sway bars making noise
Old Jan 19, 2004 | 10:35 PM
6speedG35sedan's Avatar
I just installed Eibach sway bars. I had them installed at a local Discount tire. When I turn right or left I can hear a thunk at the front sway bar. The sound is coming from the left front tire area. Anybody have any ideas what that noise may be? I checked all the nuts (only one at each side of the front sway bar) and they are all tight. I don't think it is from the bar twisting, as the sway bars do, that would be more of a squeek. This is definilty a thunk noise. I will take it into the tire place as well to let them take a look. By the way I have the front sway bar at it's stiffest setting up front.
Old Jan 20, 2004 | 06:49 PM
Re: Eibach sway bars making noise
went back to the shop today. They adjusted the small attach arm that attaches the sway bar to the lower control arm up front and the noise went away. I was on hold with Eibach tecnical support when the guy at the shop figured it out. The sway bars actually work better now. I have the front full stiff and the back at the middle setting. What a difference from stock sport package. I took a run up Mount Palomar to test them today. I'm tempted to go full stiff at the rear sway bar as well. Has anyone tried the full stiff on the Eibach rear sway bar yet? Let me know.
Old Jan 22, 2004 | 09:12 PM
Thanks for the help. I will give it a try.
Old Jan 26, 2004 | 02:28 AM
don1's Avatar
Loren04Coupe, good information/post.
Old Jan 26, 2004 | 02:25 PM
dnapoli's Avatar
Yea....that's some good tuning info! I'll gave to refer to this when a sway bar is made for the G35x.
If it's a G it's 4 me!
2004 G35x
Diamond Graphite~Graphite~Premium~Wood~Splash Guards~7 Wire Grounding Kit~Z-Tube
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
