Spacer Question
Old Jul 14, 2007 | 04:03 PM
fbw5595's Avatar
Spacer Question
I need to buy some spacers. I believe I can fit 5mm,10mm,15mm or 20mm spacers. I also need to increase the bolt length.
Is there any less of a downside to a 5mm versus a 20mm spacer on the bearing?
Do 5mm spacers come with longer bolts? If not what are my options?
Do I need anything else? New lug nuts or wheel locks?
Thanks.
Old Jul 14, 2007 | 05:12 PM
OffsetZ33's Avatar
You should be able to get away with a 5mm without extended studs. General rule of thumb is you should be able to get about 7 full turns of the lugnut.
Old Jul 14, 2007 | 05:34 PM
fbw5595's Avatar
Well, I test fit the wheels today and I do not believe that I could get 7 turns.
Old Jul 14, 2007 | 06:14 PM
fbw5595's Avatar
15mm in the front with bring the tire flush with the fender. Will the tire hit my fender?
Old Jul 15, 2007 | 10:53 AM
fbw5595's Avatar
bump
Old Jul 15, 2007 | 03:33 PM
fbw5595's Avatar
bump
Old Jul 15, 2007 | 08:57 PM
fbw5595's Avatar
I am about to order some spacers, but I am just looking for some agreement. I have measured my coupe's stock 18x8 +30 offset oem sport wheels. It looks like they can fit 15mm in the front and 20mm in the rear; as shown in this thread: https://g35driver.com/forums/brakes-suspension/121020-pics-my-car-lowered-z-springs-kics-spacers-x-drilled-rotors-death-56k.html.
The wheels I am putting on are 18x8 with a +35 offset. Can I use a 15mm(f) and 20mm(r) spacer setup on these as well and not have problems?
Thanks.
Old Jul 15, 2007 | 09:24 PM
dTor's Avatar
If you're going with a +5mm larger offset than stock (which will sink the wheel further into the fender) then you should increase your spacer sizes that are well-known to work on stock wheels (15mm front, 20mm rear) by 5mm to compensate.
You should get 20/25 or 25/30. There are several people around here who run 20/25 spacers on stock wheels and have no rubbing issues. If you want to play it safe, go with 20/25.
Old Jul 15, 2007 | 09:31 PM
fbw5595's Avatar
Thanks, for the reply. I figured that I should make them 20/25. I just don’t want to run into problems.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
