285/30/20- Quick question
Old Jul 23, 2007 | 11:13 AM
GTA_6speed's Avatar
Morning all,
Recently got a set of 20" Axis Penta's with 245/35/20 up front and 275/30/20 out back. Due to some phenomenal luck with nails (ran over one and blew a back tire the first day, had it replaced and recently ran over and blew the other back tire) i am considering going to 285/30/20. Any issues running this setup with the 245s up front? Thanks in advance for your help!
Old Jul 23, 2007 | 12:43 PM
redlude97's Avatar
Should be fine, I run a 245 in the front and a 285 in the rear in 19" sizes, however, next time to upgrade, go with 255's in the front to better match the rear width. With this setup your car is going to understeer a little more than it did before
Old Jul 23, 2007 | 12:59 PM
GTA_6speed's Avatar
good to keep in mind! thanks for the response, its much appreciated!
Old Jul 23, 2007 | 01:33 PM
Gilley's Avatar
+1. I run 255/30/20 and 285/30/20. They are about the closest match to the OEM tire diameter that you will find.
Old Jul 23, 2007 | 05:34 PM
Triple8Sol's Avatar
That's exactly what I'm running now. Like redlude said, when you get around to replacing the fronts, you can go wider too, and go down to a 30 sidewall.
Old Jul 24, 2007 | 08:32 PM
wayneside's Avatar
you should have zero problems...and hopefully better luck with nails!
Old Jul 24, 2007 | 09:47 PM
GTA_6speed's Avatar
thanks for all the input everyone, much appreciated!! I'm going to get some TPMS installed on the new rims to avoid this situation in the future!!
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
