G35 Coupe RWD question
i own a 2004 g35 coupe with stock michelin pilot sports on my 18inch stock rims, i need to replace my tires and i understand the dimension in the rear is 245/45-18, I was wondering i put on 245/40-18 wheels if it would make a difference and if it would fit? infiniti said it might set my traction control off but im askin for my opinions and if it matters
Re: G35 Coupe RWD question
As you search this board, you'll see a variety of set-ups. Having said that, generally people try to stay within 3% of the factory specs so as to not throw off the VDC system....and the speedo/odometer readings. The replacement tire that you stated falls within 3.6%....that is, speedometer reads 60 mph, actual travel speed 57.8 mph.
'03 G35 C Prem Pkg, Navi, Aero, Performance Wheel & Tire Pkg
What is the widest tire that will safley site the stock 18" performance wheels? I currently have the pilot 245/45/18 Rear and 225/45/18 front.
I would like to keep the stock wheels, just add more meat in the rear, the local Discount Tire store said I could put 275/40/18 rear and 245/40/18 front to keep the ratio right.
I am just curious if a 275 is safe on the stock 18 x 8 wheel?
<font color=black>2003 G35 Coupe, Blk/Blk</font color=black>
<font color=red>Frisco, TX</font color=red>
ChrisBruceLoans.com
ChrisBruceLoans.com
go here to see what fits what size wheel: http://www.tirerack.com/tires/tires....el=Pilot+Sport
look up your tire size then look to see the rim width range
275 is gonna take at least a 9" rim
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit<P ID="edit"><FONT class="small"><EM>Edited by 3point5SE_Auto on 02/12/04 02:28 PM.</EM></FONT></P>
Guest
Posts: n/a
i have 255/35zr-18's p-zeros in the back... imho, i felt the stock michelin's gave a lot of grip, but were not to my liking. the sidewall was too soft and squealed a lot.
yes you can use 245/40-18's on your car... 255 has a nicer flush look though, i don't like that 'too much metal, not enough rubber' look. to each his own.
'03 Infiniti G35 Coupe M6
GTR - R = g35 coupe
GTR - R = g35 coupe
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Jul 24, 2015 05:12 PM
