Tire and Wheel Sizing Chart
Old Jan 31, 2004 | 08:44 PM
Meatshackle's Avatar
Deep Sea Moderator
There's been a lot of questions on what size tires and wheels we can use and try not to throw off the traction control or speedometer. I threw a chart together with all the sizes I could think of (I'm sure I missed a few). I didn't include any sizes that would be more than a 5% difference than the factory specs. I sorted them by circumference so find your current size and see what the closest match would be in the wheel or tire you're looking at. Diameter & circumference are in inches. Generally speaking a 1" difference in circumference is going to change your speedo a little more than 1% (80 mph on your speedometer is really approx 80.8 mph if you go bigger or 79.2 mph if you go smaller).
If you don't see a size let me know. If you find this of use ask the mods to put it in the FAQ section.
Tire Size ./ Diam / Circumference
245 40 17 24.72 77.61
245 35 18 24.75 77.72
245 30 19 24.79 77.83
255 30 19 25.02 78.57
255 35 18 25.03 78.59
255 40 17 25.03 78.60
225 40 18 25.09 78.77
225 35 19 25.20 79.13
265 30 19 25.26 79.32
265 35 18 25.30 79.45
265 40 17 25.35 79.59
235 40 18 25.40 79.76
235 35 19 25.48 80.00
275 30 19 25.50 80.06
275 35 18 25.58 80.32
275 40 17 25.66 80.58
245 45 17 25.68 80.64
245 40 18 25.72 80.75
285 30 19 25.73 80.80
245 35 19 25.75 80.86
245 30 20 25.79 80.97
285 35 18 25.85 81.18
225 50 17 25.86 81.19 Coupe (Front)
295 30 19 25.97 81.54
225 45 18 25.97 81.55 Coupe 18" (Front)
255 30 20 26.02 81.71
255 35 19 26.03 81.73
255 40 18 26.03 81.74
255 45 17 26.04 81.75
305 30 19 26.20 82.28
235 50 17 26.25 82.43 Coupe (Rear)
265 30 20 26.26 82.46
265 35 19 26.30 82.59
215 55 17 26.31 82.62 Sedan (Front & Rear)
235 45 18 26.33 82.67
265 40 18 26.35 82.73
265 45 17 26.39 82.86
275 30 20 26.50 83.20
275 35 19 26.58 83.46
245 50 17 26.65 83.67
275 40 18 26.66 83.72
245 45 18 26.68 83.78 Coupe 18" (Rear)
285 30 20 26.73 83.94
275 45 17 26.74 83.98
225 55 17 26.74 83.98
245 35 20 26.75 84.00
285 35 19 26.85 84.32
225 50 18 26.86 84.33
285 40 18 26.98 84.71
255 35 20 27.03 84.87
255 45 18 27.04 84.89
255 50 17 27.04 84.90
295 35 19 27.13 85.19
235 50 18 27.25 85.57
265 35 20 27.30 85.73
265 45 18 27.39 86.00
275 35 20 27.58 86.60
245 50 18 27.65 86.81
245 40 20 27.72 87.03
275 45 18 27.74 87.12
285 35 20 27.85 87.46
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 31, 2004 | 08:51 PM
redwillow's Avatar
20 Year Member
Re: Tire and Wheel Sizing Chart
good job russ!
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Jan 31, 2004 | 10:22 PM
Deep Sea Moderator
Thanks. Just a little something I banged out on Excel.
Russ
Black 6MT Coupe
Jax, FL
Old Jan 31, 2004 | 11:09 PM
kris's Avatar
245/40/19 ??
g35.coupe.6mt.blk.blk.injen.tein.
Old Jan 31, 2004 | 11:24 PM
Deep Sea Moderator
Somehow I missed a lot of the 19 sizes....oops. Thanks.
Russ
Black 6MT Coupe
Jax, FL
Old Jan 31, 2004 | 11:29 PM
Deep Sea Moderator
There's been a lot of questions on what size tires and wheels we can use and try not to throw off the traction control or speedometer. I threw a chart together with all the sizes I could think of (I'm sure I missed a few). I didn't include any sizes that would be more than a 5% difference than the factory specs. Diameter & circumference are in inches. Generally speaking a 1" difference in circumference is going to change your speedo a little more than 1% (80 mph on your speedometer is really approx 80.8 mph if you go bigger or 79.2 mph if you go smaller).
This one's sorted by size instead of circumference. I didn't realize how hard it was to find a tire with the other chart.
225 40 19 26.09 81.91
235 40 19 26.40 82.90
245 40 19 26.72 83.89
255 40 19 27.03 84.88
265 40 19 27.35 85.87
275 40 19 27.66 86.86
285 40 19 27.98 87.85
225 45 19 26.97 84.69
235 45 19 27.33 85.81
245 45 19 27.68 86.92
Russ
Black 6MT Coupe
Jax, FL
Old Feb 1, 2004 | 02:53 AM
skeleton_cru's Avatar
Sedan
Thanks Russ!
...Skeleton Cru
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
