Another tires thread
Old Aug 31, 2007 | 04:15 PM
dunglan7's Avatar
I have a 03 with M45 wheels on them. I also have H&R 5mm spacers to keep the tires from rubbing the control arm. What size replacement tires would be best?
Old Aug 31, 2007 | 04:42 PM
ttrank's Avatar
Grocery getter
How close are the current tires to the control arm. If they are within 5mm you need to stick with whatever width you have now.
Old Aug 31, 2007 | 04:49 PM
dunglan7's Avatar
The fronts are 5mm but I think it's a little more out back. Probably 10mm.
Old Aug 31, 2007 | 05:08 PM
G SEDAN's Avatar
what sizes front and back you have now? we can give you a better recommendation that way.
Old Aug 31, 2007 | 05:16 PM
bert039's Avatar
I would say 245/40/19 or 245/35/19 but can you define your definition of "best"? Are you going for the widest tire you can get? Or are you looking for closest to stock? Or....?
Old Aug 31, 2007 | 06:06 PM
dunglan7's Avatar
My current set-up is 245/40/19 on all four corners. I'm trying to go a little wider but I don't want it to rub up against the control arms.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
derres
Aug 28, 2015 03:27 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
BlackGee35
Jul 31, 2015 11:04 AM
