nail in tire- pic
Glad there is no leak. If it does start to leak a patch should do the trick. That is right on the edge of repairable or not but if they do have to make the repair be sure to get a patch not a plug. Discount Tire does BOTH to each hole (plug AND patch).
Best of luck.
Best of luck.
Originally Posted by fredrik94087
If you really need to fix it and the tire shop tells you they can't, you can go to a corner gas station where they plug the holes. They can even do it with the tire on your car. They just pull out the nail and shove in the plug.
But, the last time I did that, it was for a 1986 Grand Am back in 1996!!!
It looks painful...
It looks painful...
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
