Tires keep losing pressure
Old Oct 2, 2007 | 07:53 PM
dickersonka's Avatar
I just had my tires replaced and ever since my left rear tire has been losing about 3psi a day. Do you guys think its a slow leak or should I take it back to the tire place and have them take a look at it? Any possibilities what might be causing this?
Old Oct 2, 2007 | 08:06 PM
redlude97's Avatar
take it back before you try anything else
Old Oct 4, 2007 | 06:53 PM
05GCOUPE6MT's Avatar
I would spray the wheel down with soapy water to see if you can find the leak. Look for bubbles. It could be from a nail, Valve Stem OR RIM. At least you will have an idea what wrong. Sometimes they leak from around the rim due to mineral buildup over the years. If not cleaned the tire will not sit flush to the RIM and leak. If this is the issue the Inner RIM lip should be cleaned/sanded prior to tire mounting. ALSO take the CAP off the valve stem and spray it to see if that leaks. Good Luck.
Old Oct 4, 2007 | 07:03 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
take it back, and check if you ran over anythign
Old Oct 5, 2007 | 06:57 AM
g35rcr's Avatar
also your bead might have not set when they put the tire on the wheel...have them remount it
JoeMac
Aug 20, 2015 10:17 AM
