Question on 04 G35 sedan 6 spoke 17s
Oct 2, 2007 | 11:29 PM
I am looking at purchasing a set of the 6 spoke 17"s from a 2004 sedan for winter use. Im sorta a noob with wheels so bear with me. I drive a fully stock 2005 G35 sedan sport model with the 18s. I know the offset on the stock 18s is 45mm but what is the offset of the 17s for the 2004 models? I cant find a straight answer on here, ive seen 45mm and 35mm. Can anybody confirm what the stock offset is on these rims:
I know for sure the bolt pattern is the same but just want to make sure the offset is same. If the offset is different, is there anything I need to do for them to work? Im hoping they will just bolt right up no problems. I plan on running 215/55/17 blizzacks on them (stock size) so i dont throw off my spedometer. Any help would be appreciated!!
Reply 0
