Sway Bars & Springs for G35x?
Old Feb 14, 2004 | 12:42 PM
dnapoli's Avatar
Does anybody know if sway bars or springs have been released for the G35x?
If it's a G it's 4 me!
2004 G35x
Diamond Graphite~Graphite~Premium~Wood~Splash Guards~7 Wire Grounding Kit~Z-Tube
Old Feb 14, 2004 | 02:29 PM
Gsedan35's Avatar
Re: Sway Bars & Springs for G35x?
Eibach is planning to release lowering springs.
No info on the sway bars. Thing is, most all of the sway bars being run on sedan's now are one's where were taking advantage of the fact that it's the same fitment as the Z. None of the manufactures have done any work to the bars to be specific to the sedan, but they don't need to. I do not see them doing anything to make bars specific to the X since of course the X uses's a different front suspension then it's FM platform mates, the Z and other G35 variant's (who know's you might want to call Eibach and just ask them if they might do a X version). What can you do? First thing I would do is to find someone local that has a oem stock front bar laying around and ask if can barrow it. Then take and remove your oem front bar and do a side by side comparision, we want to see if by chance the bars are actually the same (I doubt they will be, but it's worth a shot). Your other option is to pull the stock oem front bar off and all the mounting hardware (not the end links) and sent those parts including the bar to
http://www.sanerperffab.com/products.htm
They can custom bend you a stiffer bar to your specs, last time I checked cost is $180. On the rear bar you can get a rear only Cusco or EVO350 bar.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
zoop425
Mar 29, 2016 05:51 PM
gatorglaze
Sep 10, 2015 12:03 PM
kevintandmd
Sep 3, 2015 06:41 PM
linedr89
Aug 17, 2015 05:11 PM
wuppiedog
Aug 7, 2015 11:16 AM
