What do I need?
Old Feb 16, 2004 | 06:32 PM
FrankieBallzzz's Avatar
What do I need?
What's up guys... here's my question: I'm ordering a set of Axis Milano 19x8.5 front and 19x9.5 rear. I'm also installing the Tein S-Tech springs. I've been reading that by installing the springs alone, my wheels won't sit flat on the ground and the inside of the wheel will wear faster and high speed stability will decrease. Are new cambers what I need? I don't what to change the whole suspension, but I think that new camber arms will solve this problem. Please tell me if I'm wrong, and which brand I should go with. I really don't want to spend too much.
Thanks for all your help,
Frank
Old Feb 16, 2004 | 08:02 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: What do I need?
You'll need new camber arms because the stock arms are barely adjustable. I just had my alignment done today and on a car that is 9 months old with 11k on it I was -2.2 in the rear. They could only get it to -1.6 with the camber adjustment maxd out. Stock is -1.0 to -2.0 but I wish I was closer to -1.0. A lowered car will most likely be even more out of specs.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 16, 2004 | 08:17 PM
Hellboy's Avatar
Re: What do I need?
Hey frankieballzzz,
Post some shots of your ride when you get those. The only other shot of those I've seen on a G were really rainy and dark. I think they'll look awesome.
2004 G35 Coupe 5AT Diamond Graphite / Graphite
Performance | Premium | Aero | Clear Bra | Zaino!
