G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Wheels & Tires (https://g35driver.com/forums/wheels-tires-25/)
-   -   285's... is rolling a must? (https://g35driver.com/forums/wheels-tires/185377-285s-rolling-must.html)
Triji Oct 31, 2007 01:02 AM
If I wanted to run 285's out back (285 / 35 / 19) out back on 10.5" rims do I have to roll the fenders or can I get away with not rolling them?
Thanks.
k67p67 Oct 31, 2007 01:13 AM
Thanks.
I had to cut my rear fenders to accommodate a set of Toyo T1-R 285/35/19 on my Junction Produce 19"x10.5" +24 medium disk wheels. You may not have to cut if you run more negative camber.
istan Oct 31, 2007 01:25 AM
Neg Camber and Offset are going to help fit them.
Triji Oct 31, 2007 01:48 AM
I think I am running a 28 offset out back on 10.5" SF challenges... I have 275 / 35 / 19's currently and was going to see if 285's might work but I want to avoid cutting / rolling my fenders. I might stay safe and stick w/ the 275's...
imalazeeass Oct 31, 2007 01:49 AM
rolling/cutting is all part of the game! =)
Sundeviljay Oct 31, 2007 01:55 AM
^for sure...or go one step further and hammer them out so they are even wider :)
Triji Oct 31, 2007 02:19 AM
Lol... um, yeah... you guys are just tooooooo funny!! :p :p :bowrofl:
ok, ok, ok.... so I wused out and ordered the 275's again... they look good on there and I know they preform incredible.
might look into spacers to kick out the fronts 10-15mm to line up better with the CF fenders and I would need to do the rears as well to even it out.
Sundeviljay Oct 31, 2007 02:50 AM
i was finally able to put 285's cuz I had the shop widen my rear fenders when i had all the work done
SilverII Oct 31, 2007 11:22 AM
i rubbed a little when i put 285.... but not anymore once i rolled it
Triple8Sol Nov 1, 2007 07:48 PM
You should be fine with your offset. Just depends on your camber/drop.
misSxhuStLer Nov 1, 2007 08:49 PM
I have 285/35/19 Toyo T1R and 10.5+18. It wouldn't happen all the time, but it would occasionally rub. Haven't had any problems since I got the rear fenders rolled.
Vinny@VTR Nov 2, 2007 10:25 AM
with a +28 offset... and close to factory camber settings, you wouldnt need to roll or cut the fenders.
Triji Nov 2, 2007 12:20 PM
Thanks for the feedback... It is either a 23 or 28 on the rears, cant really remember :o I had the barrels chromed do the sticker is gone now.... I ordered the 275's to be safe as I am dropped on Espelir GT springs as well.
Thanks for the feedback, here is a shot of her with the 275's out back... looks kinda tight for 285's actually.
http://www.az350z.com/photopost/data..._00081-med.JPG
© 2026 MH Sub I, LLC dba Internet Brands
