285's... is rolling a must?
Old Oct 31, 2007 | 01:02 AM
Triji's Avatar
If I wanted to run 285's out back (285 / 35 / 19) out back on 10.5" rims do I have to roll the fenders or can I get away with not rolling them?
Thanks.
Old Oct 31, 2007 | 01:13 AM
k67p67's Avatar
Thanks.
I had to cut my rear fenders to accommodate a set of Toyo T1-R 285/35/19 on my Junction Produce 19"x10.5" +24 medium disk wheels. You may not have to cut if you run more negative camber.
Old Oct 31, 2007 | 01:25 AM
istan's Avatar
Neg Camber and Offset are going to help fit them.
Old Oct 31, 2007 | 01:48 AM
Triji's Avatar
I think I am running a 28 offset out back on 10.5" SF challenges... I have 275 / 35 / 19's currently and was going to see if 285's might work but I want to avoid cutting / rolling my fenders. I might stay safe and stick w/ the 275's...
Old Oct 31, 2007 | 01:49 AM
imalazeeass's Avatar
rolling/cutting is all part of the game! =)
Old Oct 31, 2007 | 01:55 AM
Sundeviljay's Avatar
^for sure...or go one step further and hammer them out so they are even wider
Old Oct 31, 2007 | 02:19 AM
Triji's Avatar
Lol... um, yeah... you guys are just tooooooo funny!!
ok, ok, ok.... so I wused out and ordered the 275's again... they look good on there and I know they preform incredible.
might look into spacers to kick out the fronts 10-15mm to line up better with the CF fenders and I would need to do the rears as well to even it out.
Old Oct 31, 2007 | 02:50 AM
i was finally able to put 285's cuz I had the shop widen my rear fenders when i had all the work done
Old Oct 31, 2007 | 11:22 AM
SilverII's Avatar
i rubbed a little when i put 285.... but not anymore once i rolled it
Old Nov 1, 2007 | 07:48 PM
Triple8Sol's Avatar
You should be fine with your offset. Just depends on your camber/drop.
Old Nov 1, 2007 | 08:49 PM
misSxhuStLer's Avatar
I have 285/35/19 Toyo T1R and 10.5+18. It wouldn't happen all the time, but it would occasionally rub. Haven't had any problems since I got the rear fenders rolled.
Old Nov 2, 2007 | 10:25 AM
Vinny@VTR's Avatar
with a +28 offset... and close to factory camber settings, you wouldnt need to roll or cut the fenders.
Old Nov 2, 2007 | 12:20 PM
Triji's Avatar
Thanks for the feedback... It is either a 23 or 28 on the rears, cant really remember I had the barrels chromed do the sticker is gone now.... I ordered the 275's to be safe as I am dropped on Espelir GT springs as well.
Thanks for the feedback, here is a shot of her with the 275's out back... looks kinda tight for 285's actually.
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
ncg35guy
Sep 26, 2015 04:04 PM
