M35 19" wheels
Old Nov 4, 2007 | 01:16 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Texasscout
Here you go, check this out.
Prolly gonna last just as long.
Old Nov 8, 2007 | 05:13 PM
ashish's Avatar
stock m45 tires are 245/40/19 not 245/35/19
Old Nov 8, 2007 | 06:06 PM
aleok's Avatar
i picked up my M rims for $500 flat.
Old Nov 8, 2007 | 08:35 PM
Texasscout's Avatar
I know, but that would be too much circumference. I would like to keep the over all outside diameter as close to stock as I can.
Old Nov 8, 2007 | 09:11 PM
blkonblk17's Avatar
did you ever put them on your g?
I was reading some where that someone put the m45 wheels on the G coupe and had to run spacers in the front because the wheel would hit the a arm or something metal so they had to use a spacer.. just my 50cents research and research before you make any type of deal
Old Nov 9, 2007 | 12:15 PM
jonE5's Avatar
yeah, dont you need spacers for these?
Old Nov 9, 2007 | 12:42 PM
ttrank's Avatar
Grocery getter
You need spacers for the front to clear the brakes. The rears look a lot better with spacers but are not required.
Old Nov 9, 2007 | 12:47 PM
jonE5's Avatar
What MM spacers do you need?
Do you also have to get aftermarket longer studs?
Old Nov 9, 2007 | 12:55 PM
ttrank's Avatar
Grocery getter
I belive you need at least a 5mm front spacer to clear the brakes.
Some run the 5mm with the stock studs but I wouldn't. IMO anything over 3mm needs longer studs to be safe enough to make me happy.
Old Nov 9, 2007 | 06:16 PM
Texasscout's Avatar
The guy that has these did not run any spacers. He has a 2005 model. Said he had no issues with them.
Old Nov 9, 2007 | 06:22 PM
ashish's Avatar
was the guy running this on a coupe or sedan before?
Old Nov 9, 2007 | 08:21 PM
aleok's Avatar
yea i had them on for a few months. yes you need spacers, 25mm minimum, for the coupe. heres a pic from a while back.
Old Nov 9, 2007 | 09:05 PM
Texasscout's Avatar
Sedan
Old Sep 17, 2010 | 08:54 PM
BippU_V35's Avatar
What are the tire size, 245/40/19 x4?
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
